I need to explode the block and move all entities to given layer. Pl. give me a LISP code.
Here you go
(defun rh:ex2layer ( obj lyr / objs)
  (cond ( (vlax-method-applicable-p obj 'explode)
          (setq objs (vlax-safearray->list (vlax-variant-value (vla-explode obj))))
          (foreach e_obj objs
            (vlax-put-property e_obj 'layer lyr)
          );end_foreach
  );end_cond
);end_defun
Have you tried the existing XPLODE command?
(command "-layer" "N" "lyr" "")
(command "insert" "QkBeam" "non" (LIST 0 0) 100 100 "0")
(setq OBJ (entlast))
(rh:ex2layer)
          (foreach e_obj objs
          );end_foreach
  );end_cond
);end_defun  ur
It is not working.Something wrong somewhere.
You are not calling the subfunction with the correct arguments...
Perhaps something a little easier for you to use:
(defun c:foo (/ l lyr o s)
  ;; RJP » 2018-08-23
  (setq lyr "test")
  (or (tblobjname "layer" lyr)
      (vla-add (vla-get-layers (vla-get-activedocument (vlax-get-acad-object))) lyr)
  (cond	((setq s (ssget ":L" '((0 . "insert,*polyline,region"))))
	 (foreach x (vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))
	   (setq o (vlax-ename->vla-object x))
	   (cond ((= 'list (type (setq l (vl-catch-all-apply 'vlax-invoke (list o 'explode)))))
		  (foreach y l (vla-put-layer y lyr))
		  (entdel x)
(vl-load-com)
Edited by ronjonp
poor grammar ;\
  • Thanks 1
(rh:ex2layer)
          (foreach e_obj objs
          );end_foreach
  );end_cond
);end_defun  ur
No, it is working but you're not using it correctly. It is a function and needs to be called like this:
(rh:ex2layer object "layer name")
It needs to be an object but you are setting obj to an entity. This needs to be converted by replacing your setq with this
 (setq obj (vlax-ename->vla-object (entlast)))
"layer name" needs to be the layer name of any valid layer that exists in the drawing.
And while we are there you will need
(vl-load-com)
somewhere in your lisp. If you want to use it "inline" I suggest this
(command "-layer" "N" "lyr" "");YOU DON'T HAVE TO CREATE A NEW LAYER
(setq lyr "lyr"						;REPLACE "lyr" WITH THE NAME OF THE LAYER YOU WANT THE EXPLODED ITEMS TO GO TO
);end_setq
(vl-load-com)
          (foreach e_obj objs
          );end_foreach
);end_cond
  • Thanks 1
