Generate Boundary Line By Selecting Intersecting lines
Hi All im looking for lisp routine that does the following.
1. Generate boundary line by selecting intersecting lines or blocks as shown above.
2. Set the generated boundary to specific layer, say Boundary Lines
Thanks in Advance
Note: Cannot attach image not sure why. hopefully someone can understand my post :) Thanks
Edited by loudy000
cannot attach image
Those arch-like things ... are they always arcs?
Nope sometimes lines, polylines or would be good if can be anything
Have you tried Bpoly it uses a pick point and makes a boundary.
(command "_.Bpoly" (getpoint) "")
 (command '_.BPoly" (getpoint) "")
Edited by BIGAL
"_.Bpoly"
You can use a fence option with ssget crossing the vertical lines to do multiples, pretty sure fence returns the crossing order of objects. Will test.
Can you take a step back and create the bpoly as you create the vertical lines wold be a better way to approach the problem. Please explain more the situation of how you end up with the drawing.
So the process is we first create those lines using measure command to get exactly the desired area or spacing between plots, the sizes may vary depending on the required area. After that we need to model those plots which requires polylines(closed).
I would pay $14 then I could use the spare time to play here at cadtutor and the boss would not know.
  • Funny 1
yeah that's probably a good idea :D thanks mates
  On 8/27/2018 at 3:00 PM, Stefan BMR said:
Hi
You can try the Enclosed Polylines.lsp from here.
Expand
Awesome!!! Many thanks!, Can this work with blocks as well?
    (setq ss (ssget ":L" '((0 . "LINE,LWPOLYLINE,ARC,CIRCLE,BLOCK"))))
Tried that but didn't work. Thnks
The thing you select is not a block, but rather an insert. Try like that
(setq ss (ssget ":L" '((0 . "LINE,LWPOLYLINE,ARC,CIRCLE,INSERT"))))
Cheers
It will not work with blocks. It needs curve objects.
Expand
I see, Thanks :)
Cheers
Expand
Thanks Jef it works for selection only but not for the whole routine as ronjonp was saying
Expand
I just replied to your ssget question. I'm not a member of the swamp, therefore I cannot see the routine attached by Lee. Sorry I cannot be of further assistance.
Expand
no worries :) see attached if you want to have a look at it. Cheers!
Enclosed polylines.LSP
