Can't change layer or colour
Hi All,
Not sure if any of you have had this problem but, here goes.
Every time I select something & change its colour or even layer it doesn't seem to work.
I can change it form the properties sidebar, but its annoying that everything is drawn on layer 0 as black rather than what's set up - even the line types don't work!
Also, when something's selected the commands wont work - I have to initiate the command first then select them.
Select the layer or linetypes you wan't to work with first
and then start drawing,
If you forget to switch layers you can 'matchprop' after your done drawing. this is faster than selecting everyting and then setting them on the right layer or linetypes.
Which commands are you talking about?
something's not right, I cant freeze layers in the viewport now!
Pickfirst is set to 0
And no matter what my layers are set to, its all on layer 0 when I draw - I cant have something on a right layer to match it!
Curse!
well I'll be damned, thats what it does!
Thanks CAD, how did I miss this one?....
  • 2 weeks later...
I have this problem with layers, sometimes when i use layers from another drawing, in my drawing, the properties of layers doesnt take effect, e.x. if i want to change the thickness or the color of the layer they doesnt take effect. Why?!
Click on an entity and check it's Properties. Make sure that "Color" and "Linetype" are both set to ByLayer.
  • 1 year later...
Pickfirst should be set to 1.
thank you sooooo much! i had the same problem, pickfirst to 1 fixed all :D
  • 8 months later...
Thanks a punch, I've been looking for a solution to this problem for a long time. Awesome!:)
What ever happened to the Idea of putting "DOES PICKFIRST=1" as a header at the top of the screen?
Why have it an option at all?????:( Why would anyone want it set to 0?
  • 10 years later...
Thanks a TON!
