stevo Posted August 15, 2018 Posted August 15, 2018 When selecting the layer that the blocks reside in, and turning off the layer, the blocks remain visible. All other items on that layer do turn off. How do I fix this? Thanks. Quote
RobDraw Posted August 15, 2018 Posted August 15, 2018 The entities in the block are on a different layer. However, if that layer needs to be on for other objects, turning them off may not be an option and you will have to find another way to get what you want. Quote
CyberAngel Posted August 16, 2018 Posted August 16, 2018 Entities inside a block don't always behave the way you might expect. Blocks are all about inheritance. When you insert a block, you're really inserting an instance of the block. It's a reference to the definition of the block, which is off in a table somewhere. The block reference has its own layer assignment. When you assign an item to layer 0 inside a block, it's like assigning the color ByLayer. In a block instance, that entity takes on, or inherits, the layer of the instance. For any other layer, an entity keeps the layer it had inside the block definition, that is, it's not inherited. Sorry if you knew that already, but as RobDraw guessed, that's probably what's happening. If you can't fix the problem by redefining the block, please give us more information or post the block. Quote
tombu Posted August 16, 2018 Posted August 16, 2018 That's how it's always worked. Just freeze the block's layer. 1 Quote
Metachik Posted September 22, 2018 Posted September 22, 2018 If it was my misbehaving block, I would double click on the block to open it and put all its components onto the one layer that I want it on. Quote
