Hello,
I have moved to a new office with a new computer, and I am trying to set up ACAD to where it PUBLISHes all the sheets to a single PDF, with PUBLISH quality (not plot quality).
I have ten (10) layouts in a drawing, and all the layouts are set up the same way in Page Setup mgr. In page setup manager, for each one of the layouts, I've selected the BlueBeam PDF printer/plotter, an ARCH_E1 _(30.00_x_42.00_Inches) Paper size, a 'Plot style table' set to monochrome.ctb (SHOULD IT BE .stb???) with 'display plot styles' checked. Actually, just see this:
Here are the problems:
1. The computer wants to publish by plotting ONE SHEET AT A TIME AND ASKING ME WHAT TO NAME IT AND WHERE TO PUT IT EACH TIME..
2. The quality of the resultant PDF is terrible, and looks like it was plotted individually instead of published (I have noticed a difference between plotting and publishing). See this:
I need some assistance, please!
Thanks!
This uses standard Dwg to pdf never had any problems with quality, it also uses Ghostscript to make a combined pdf of your singles as well as a range of layout select ability its just 1 of many that have been posted here. Search maratovich as well he has a good publish routine.
plota3colrange.LSP
mattador04
1. Do you use Publication or by hand printing?
2. Why do not you use DWG to PDF?
Huh? Publication, I guess, since I am used to running the PUBLISH command. I do not know why I don't use the DWG to PDF... I have had the option to choose 'Bluebeam' as the plot device within AtuoCAD, and thus I have not chosen 'DWG to PDF'. Will this option produce the results I seek (see original post)?
Thanks,
Mathew
Like Maratovich and as I said earlier use dwg to pdf no quality problems.
Ok, thank you for the responses. I shall try setting the drop-down to "DWG to PDF" and report back.
-Mathew
  • 2 weeks later...
I have not yet had time to reinvestigate this, as I have been using Revit for the last three (3) weeks!
-MR
