K Baden Posted August 8, 2018 Posted August 8, 2018 Good morning! I have not had any luck in finding much that my novice LISP skills can fix up to suit my needs. Perhaps someone here has something laying around? I am looking to have a LISP that does the following: allows the user to select one or more dimensions Allows user to pick from 3-4 options with the underlined letter being what the command needs: (XHM), (THR), (YJM), and (CPA) Then add the user selected string as a dimension suffix to the selected dimension. We add suffixes to dimensions often, and there are several different ones we use daily. Just looking to save time by having a command that will add the selected string to the suffix. Does anyone have anything similar? I am able to do some editing to suit my needs, but I don't even know where to start with editing a dimension suffix via LISP. Thanks in advance! Quote
tombu Posted August 8, 2018 Posted August 8, 2018 Few ideas at: http://forums.augi.com/showthread.php?129908-Text-Override-in-Dimension&p=1127451&viewfull=1#post1127451 I use Alan's DQE.lsp, you just have to modify the values in the line (setq lst '("<>" "± VIF" "EQ." "± VERIFY")) Mine is set to (setq lst '("" "Easement" "<> R.O.W." "Varies" "<>\\XVaries" "<> Varies" "<>±")) " R.O.W." adds the suffix R.O.W. to the dimension. Quote
ronjonp Posted August 8, 2018 Posted August 8, 2018 Here's a function you can use. Wrap it into your code with the options you want. (defun _putsuffix (e suf / o) (if (and (= 'ename (type e)) (vlax-property-available-p (setq o (vlax-ename->vla-object e)) 'textsuffix) (vlax-write-enabled-p o) ) (vla-put-textsuffix o suf) ) ) (_putsuffix (car (entsel)) "CPA") Quote
