I notice that wildcart search is not always the ultimate way to go since it call unrelevant layers. I need a toggle to be able to search the whole word or wildcard. How can it be done?
guess whole word search can have 2 situations , word is the first word so it would end with a space , or it is the last word , so it would begin with a space.
e.g. "walls and windows" (or "walls_and_windows") or "windows_and_walls". Your filter would be *walls* for any match , "walls *" for any line beginning with walls or "* walls" for strings ending with walls.
  • Replies 25
  • samifox
    13
  • rlx
    9
  • Lee Mac
    2
  • Tharwat
    2
from my tests this search crateria is not always welcome,
im not looking for general layers names but specific names i know my client always use.
so "parking roof" is not relevant but "roof" is
the wildcard is needed when the xref has been bind, in this situation it layer name will include the prefix of the file
(defun c:samifox ( / doc fn fp s p l o n c wc)
 (vl-load-com)
 (setq doc (vla-get-activedocument (vlax-get-acad-object)) fn (findfile "map.txt"))
 (princ "\nPress space bar to include wildcard or any other key or button for none")
 (if (equal (grread) '(2 32)) (setq wc "*")(setq wc ""))
 (cond
   ((null fn)(princ "\nData file map.txt not found"))
   ((not (setq fp (open fn "r")))(princ "\nUnable to read from map.txt"))
   (t
    (while (setq s (read-line fp))
      (if (setq p (vl-string-position (ascii ",") s))
        (setq l (cons (cons (substr s 1 p) (substr s (+ 2 p))) l))))
    (if (vl-consp l)
      (vlax-for o (vla-get-layers doc)
 (setq n (strcase (vla-get-name o)))
 (if (vl-some '(lambda (x) (if (wcmatch n (strcase (strcat wc (car x) wc))) (setq c (cdr x)))) l)
   (vl-catch-all-apply 'vla-put-color (list o c))))))
 (vl-load-com)
 (cond
   (t
    (if (vl-consp l)
thanks
ive used space bar but it doesnt work
 (vl-load-com)
 (cond
   (t
    (if (vl-consp l)
sorry ive read the wrong file
its working perfect
thanks you!!!
its working perfect
thanks you!!!
one appie for you and one air mile for me :D
