Damilola Posted August 1, 2018 Share Posted August 1, 2018 Hi Everyone, I'm currently sinking in opened links on finding a vertical wood grain hatch pattern. I finally found a hatch pattern close to what i have, but now it needs to be rotated by abut 27degrees. Could anyone please help with this. Attached is a sample of the Pattern legno4 - Kopie.pat.txt Quote Link to comment Share on other sites More sharing options...
hugha Posted August 2, 2018 Share Posted August 2, 2018 That is a Revit model pattern that can also be used in AutoCAD. If you are working in Revit, you can 1) rotate a model pattern in situ where it has ben used as a surface pattern 2) use the free HatchKit Add-In for Revit to rotate the fill definition or create another rotated fill within the project. 3) load a pre-rotated pattern from a .PAT file. If you are working in AutoCAD you can 1) rotate a hatch pattern while specifying a hatched area using that pattern 2) use a pre-rotated pattern from a custom .PAT file. Here is your posted pattern rotated 27 degrees, suitable for Revit ot AutoCAD: ;------------------------------------------------------------------------------- ; Written by HatchKit Team Edition Trial ; HatchKit Team Edition Trial ©1990-2018 Cadro Pty Ltd ; www.hatchkit.com.au/ ;------------------------------------------------------------------------------- ;-Date : 2018-08-02 ;-Time : 15:06:12 ;-HatchKit Team Trial Version : 3.1.11.2768 ;-HatchKit Team Trial Output Filetype : Revit with HatchKit Add-In ;------------------------------------------------------------------------------- ;%VERSION=3.0 ;%UNITS=MM *WOOD-REVIT ;%TYPE=MODEL 53.5650716758,-0.090797,0.1782,1.34164136,0.44721392,1.118,-1.1180684 45.434964197,0.3564,0.1816,0.948683222744,-0.316228023757,0.63246,-2.52981797483 63.8699222443,-0.31779,0.6237,3.60000102367,-0.200000116499,0.5,-4.50000166028 Quote Link to comment Share on other sites More sharing options...
