[LISP] Parse/split list by element
ziele_o2k
Any other propositions to parse/split list by element:
(defun pz:LST_Parse (@lst @Sep @Rbl / _el _res)
 (setq _el nil)
 (foreach # @lst
   (if (= @Sep #)
     (setq _res (cons _el _res) _el nil)
     (setq _el (append _el (list #)))
 (setq _res (cons _el _res))
 (reverse
   (if @Rbl (vl-remove nil _res) _res)
Example:
(cd:LST_Parse '("#" "ASD" "ASDD" "DSA" "#" "FDS" "gfsfg") "#" nil)
(cd:LST_Parse '("#" "ASD" "ASDD" "DSA" "#" "#" "FDS" "gfsfg") "#" t)
(defun foo (l c m / o n)
 (while l
   (if	(/= (car l) c)
     (setq n (cons (car l) n))
     (setq o (cons (reverse n) o)
    n nil
   (setq l (cdr l))
 (vl-remove m (reverse (cons n o)))
Example:
_$ (foo '("#" "ASD" "ASDD" "DSA" "#" "#" "FDS" "gfsfg" "#") "#" t)
(nil ("ASD" "ASDD" "DSA") nil ("FDS" "gfsfg") nil)
_$ (foo '("#" "ASD" "ASDD" "DSA" "#" "#" "FDS" "gfsfg" "#") "#" nil)
(("ASD" "ASDD" "DSA") ("FDS" "gfsfg"))
(defun [b][color="blue"]pz[/color][/b]:LST_Parse (...
Example:
([color="blue"]cd[/color]:LST_Parse '("#" "ASD" "ASDD" "DSA" "#" "FDS" "gfsfg") "#" nil)
Makes you wonder...
Edited by pBe
Another two, depending on the desired behaviour:
(defun parselst ( sep lst / tmp )
   (if (setq lst (vl-member-if '(lambda ( x ) (setq tmp (cons x tmp)) (= sep x)) lst))
       (cons (reverse (cdr tmp)) (parselst sep (cdr lst)))
       (list (reverse tmp))
(defun parselst2 ( sep lst / tmp )
   (cond
       (   (null lst) lst)
       (   (null (setq lst (vl-member-if '(lambda ( x ) (setq tmp (cons x tmp)) (= sep x)) lst)))
       (   (cdr tmp)
           (cons (reverse (cdr tmp)) (parselst2 sep (cdr lst)))
       (   (parselst2 sep (cdr lst)))
Another variation:
(defun parselst3 ( sep lst / idx tmp )
   (cond
       (   (null lst) lst)
       (   (null (setq idx (vl-position sep lst)))
           (list lst)
       (   (< 0 idx)
           (repeat idx (setq tmp (cons (car lst) tmp) lst (cdr lst)))
           (cons (reverse tmp) (parselst3 sep (cdr lst)))
       (   (parselst3 sep (cdr lst)))
Another, for lists with string items only:
(defun parselst4 ( sep lst )
   (if lst (read (apply 'strcat (append '("((") (mapcar '(lambda ( x ) (if (= x sep) ")(" (vl-prin1-to-string x))) lst) '("))")))))
thanx Lee , my body was already melting cause of the heatwave and now my mind is melting too.... again , thank you so much ... :sweat:
my $0.02
if content of string has "#" ? keep or parse ?
'("#" "ASD" "AS[color="red"]#[/color]DD" "DSA" "1 ""2" "#" "FDS" "gfsfg" "#")
;also string has many possibilities
[color="purple"]"#" " #" "# " " # " "# #"[/color]
:thumbsup:
nice idea though
(parselst4 "#" '("#" "ASD" "ASDD" "DSA" " #" "#" " #" "FDS" "gfsfg" "#" " # ") )
(nil ("ASD" "ASDD" "DSA") nil ([color="red"]" #"[/color] "FDS" "gfsfg") ([color="red"]" # "[/color]))
(nil ("ASD" "ASDD" "DSA" [color="red"]" #"[/color]) ([color="red"]" #"[/color] "FDS" "gfsfg") ([color="red"]" # "[/color]))
same bug here - brackets must be paired otherwise
; error: malformed list or extra right paren on input
Well , that's (partly) a matter of dic : data integrity check :P
Thanks Lee
  (defun pz:LST_Parse (@Lst @Prd @Rbl / _el _res)
   (setq _el nil)
   (foreach # @Lst
     (if (apply @Prd (list #))
   (reverse
Edited by ziele_o2k
