Rounding TEXT into 2 decimal places
ScoRm
okay, please keep in mind, I do not have any training about lisp or any programing.
I only come up with this code by searching and I'm stuck! I need someones help
i copied some code, so I do not own any of it...
all I want is to select some text objects and round it to 2 decimal places.
(defun c:rrounding (/ ss d e)
 (and (setq obj (car (entsel "\nPick text object :")))
      (setq obj (vlax-ename->vla-object obj))
      (wcmatch (vla-get-objectname obj) "AcDb*Text")
      (vla-put-textstring obj (LM:roundto atof(obj) 2))
;(setq ss (ssget "_:S" '((0 . "MTEXT,TEXT"))))
;(LM:roundto atof(ss) 2)
(defun LM:roundto ( n p )
   (LM:roundm n (expt 10.0 (- p)))
(defun LM:roundm ( n m )
   (* m (atoi (rtos (/ n (float m)) 2 0)))
I Admit, IDK what i'm doing im sorry
Try this:
(defun c:rrounding (/ obj)
      (vla-put-textstring obj (rtos (lm:roundto (atof (vla-get-textstring obj)) 2) 2 2))
;; Multiple selection
(defun c:foo (/ o s)
 (if (setq s (ssget ":L" '((0 . "*text"))))
   (foreach a (vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))
     (setq o (vlax-ename->vla-object a))
     (vla-put-textstring o (rtos (lm:roundto (atof (vla-get-textstring o)) 2) 2 2))
(defun lm:roundto (n p) (lm:roundm n (expt 10.0 (- p))))
(defun lm:roundm (n m) (* m (atoi (rtos (/ n (float m)) 2 0))))
