farycj Posted July 22, 2018 Posted July 22, 2018 Hi, I try to plot my drawings in this new template that i created - with all those new layer. I have compared it with my other drawings, the layer properties is pretty much the same however for this drawing, some of my layer are not visible in the viewport and missing when i plot the view. All layer missing are in white colors. Do you guys happened to know why this is happening and what are the solution? Thanks. Quote
ReMark Posted July 22, 2018 Posted July 22, 2018 Are the layers frozen or turned off? Are the layers frozen in that particular viewport? Are the objects on a layer called DefPoints? Is layer "0" frozen? Quote
farycj Posted July 22, 2018 Author Posted July 22, 2018 No. The layer is not frozen or turned of - its not in defpoint layer. I also checked to make sure its visible in plotter. Layer 0 also not frozen. Its weird i know, i just cant figured why and how to fix it. Quote
eldon Posted July 22, 2018 Posted July 22, 2018 Make sure your colour white is the Index Color 7 instead of the True Color 255, 255, 255 Quote
OMEGA-ThundeR Posted July 23, 2018 Posted July 23, 2018 check the layermanager if the layers don't have a non-plot setting (printer icon) Quote
tombu Posted July 23, 2018 Posted July 23, 2018 SLW210 said: Post the .dwg. and post the plot style (CTB or STB) as well as we cannot see how it should plot without it. Quote
CyberAngel Posted July 23, 2018 Posted July 23, 2018 eldon said: Make sure your colour white is the Index Color 7 instead of the True Color 255, 255, 255 This is relevant because AutoCAD knows to change color 7 so that it will print. The true white will print as white, meaning it won't show up on white paper. Try changing the layer color. If it does print as some other color, you've found the problem. Quote
