GreenWhale Posted July 5, 2018 Posted July 5, 2018 Hi, Good day to you all.I'm new to this forum. I hope you people can help me out. I'm working on, automatic creation of title block with required scale setting in 'Model space' not in layout. by clicking a button or comment, it should ask the user to select the 'title blocks' among the list, which is in 1:1 scale. Then it should ask the user to select the scale among '1:2, 1:10, 1:20'. once selected it should scale the title block(eg. if 1:10 selected entire title block to be scaled to 10). also the size of dimension arrow and text size to be changed accordingly. Also we have a set of 10 drawing each as a blocks in it which we will be using as symbols on drawings. that should also get scaled accordingly whenever they gets inserted. please help. Quote
ReMark Posted July 5, 2018 Posted July 5, 2018 Why bother using AutoCAD 2014 then? Might as well be using release 9. Quote
GreenWhale Posted July 5, 2018 Author Posted July 5, 2018 it is not up to me. My organisation is little reluctant to get updated:unsure: Quote
BIGAL Posted July 6, 2018 Posted July 6, 2018 Try updating to layouts as the 1st step, will open a whole new world of simplicity. Quote
GreenWhale Posted July 6, 2018 Author Posted July 6, 2018 Try updating to layouts as the 1st step, will open a whole new world of simplicity. I suggested it already, yet they want in that way.. Quote
SLW210 Posted July 9, 2018 Posted July 9, 2018 I'll look around in some of my old LISPs when I get home tonight and see if I have something, like others this is ancient stuff, but it was a common request quite a while back. A good search should bring up something from way back. You might could handle this with a dynamic block with visibility states for the different scales. Quote
GreenWhale Posted July 9, 2018 Author Posted July 9, 2018 after some searches i came across with with some idea. i'm trying to create a lisp myself. which i never did before. I'm thinking of incorporating there two command lines in the lisp. looks simple two use them. however i'm stuck with automatic scaling of block... (command "insert" "C:\\Users\\DE14\\Desktop\\A1 horizondal test.dwg" "0,0,0" "1" "1" "0" "_.explode" "_L") (command "-purge" "B" "YourBlockName" "N" "") also i came across with autocad cui. and reading about them now. and i'm very much close to the solution. But the 'scale' thing is not moving... Quote
SLW210 Posted July 9, 2018 Posted July 9, 2018 I have moved your thread to the AutoLISP, Visual LISP & DCL Forum. Quote
rkmcswain Posted July 9, 2018 Posted July 9, 2018 I suggested it already, yet they want in that way.. No offense, but any organization that can't update to layouts almost 20 years later, is probably way behind in many other ways too. I'd be looking for another job. Good luck. Quote
rlx Posted July 9, 2018 Posted July 9, 2018 No offense, but any organization that can't update to layouts almost 20 years later, is probably way behind in many other ways too.I'd be looking for another job. Good luck. haha , that sounds familiar! @my work we can (and do) use layouts but... our document control program , DvTDM release 2010 , can't (so says upper control smurf) read our titleblocks in paper space (yeah right). Quote
rlx Posted July 10, 2018 Posted July 10, 2018 Rlx is it 1 dwg per sheet as well ? sadly but yes.... Quote
rlx Posted July 10, 2018 Posted July 10, 2018 just some lunch fun to get you started. Kept it as simple as possible. All could be done by dialog and / or automatically show all filenames in your template folder etc. Wanted to post earlier but major W10 update stopped me from doing anything for 3-4 hours. (defun c:Captain_Ahap ( / SizeList ScaleList size scale titleblockfolder titleblock) (vl-load-com) ; some shortcuts for titleblock / border sizes (without the full path) (setq SizeList (list "A0" "A1" "A2" "A3" "A4-L" "A4-P") ScaleList (list 1 10 50 100) titleblockfolder "c:/temp/mytitleblockfolder/" ) (if (and (setq size (CycleList "Choose titleblock size" SizeList)) (setq scale (CycleList "Choose titleblock scale" ScaleList))) (progn ; maybe translate size to filename first (cond ((eq size "A0") (setq titleblock (strcat titleblockfolder "A0_horizondal_test.dwg"))) ((eq size "A1") (setq titleblock (strcat titleblockfolder "A1_horizondal_test.dwg"))) ((eq size "A2") (setq titleblock (strcat titleblockfolder "A2_horizondal_test.dwg"))) ((eq size "A3") (setq titleblock (strcat titleblockfolder "A3_horizondal_test.dwg"))) ((eq size "A4-L") (setq titleblock (strcat titleblockfolder "A4_Landscape_test.dwg"))) ((eq size "A4-P") (setq titleblock (strcat titleblockfolder "A4_Portrait_test.dwg"))) ) (if (and titleblock (findfile titleblock) (numberp scale)) (progn (setvar 'expert 2) (setvar 'cmdecho 0) (setvar 'attreq 0) (command "-insert" titleblock (list 0 0 0) scale scale 0) (command "_.explode" "_L") (command "-purge" "B" "YourBlockName" "N") (command "._zoom" "e") ) (alert "Unable to insert titleblock") ) ) ) (princ) ) ; example1 (setq choise (CycleList "Choose titleblock size" '("A0" "A1" "A2" "A3" "A4"))) ; example2 (setq choise (CycleList "Choose titleblock scale" '(1 10 50 100))) (defun CycleList (msg lst / inp loop rtn) (setq loop t) (while loop (princ "\nCycle list with tab or L-mouse / accept use enter,space or R-mouse / Esc or x for exit\n") (princ (strcat "\r" msg " <" (vl-princ-to-string (car lst)) "> : ")) (setq inp (vl-catch-all-apply 'grread (list nil 8 0))) (if (vl-catch-all-error-p inp) (progn (princ "\nTitleblock insertion cancelled")(setq rtn nil loop nil)) (progn (cond ;tab ((or (equal inp '(2 9))(= (car inp) 3)) (setq lst (append (cdr lst)(list (car lst)))) (princ (strcat "\r" msg " <" (vl-princ-to-string (car lst)) "> : "))) ;enter,space,r-mouse ((or (equal inp '(2 13)) (equal inp '(2 32))(= (car inp) 25)) (setq rtn (car lst) loop nil)) ;x or X ((member inp '((2 88)(2 120)))(setq rtn nil loop nil)) ) ) ) ) (terpri) rtn ) ; start command with (c:Captain_Ahap) well , (work)day is done , so I'm gone ... with the wind (or the waves since you're obviously have a fishy thing ;-) gr. Rlx Quote
GreenWhale Posted July 11, 2018 Author Posted July 11, 2018 just some lunch fun to get you started. Kept it as simple as possible. All could be done by dialog and / or automatically show all filenames in your template folder etc. Wanted to post earlier but major W10 update stopped me from doing anything for 3-4 hours. (defun c:Captain_Ahap ( / SizeList ScaleList size scale titleblockfolder titleblock) (vl-load-com) ; some shortcuts for titleblock / border sizes (without the full path) (setq SizeList (list "A0" "A1" "A2" "A3" "A4-L" "A4-P") ScaleList (list 1 10 50 100) titleblockfolder "c:/temp/mytitleblockfolder/" ) (if (and (setq size (CycleList "Choose titleblock size" SizeList)) (setq scale (CycleList "Choose titleblock scale" ScaleList))) (progn ; maybe translate size to filename first (cond ((eq size "A0") (setq titleblock (strcat titleblockfolder "A0_horizondal_test.dwg"))) ((eq size "A1") (setq titleblock (strcat titleblockfolder "A1_horizondal_test.dwg"))) ((eq size "A2") (setq titleblock (strcat titleblockfolder "A2_horizondal_test.dwg"))) ((eq size "A3") (setq titleblock (strcat titleblockfolder "A3_horizondal_test.dwg"))) ((eq size "A4-L") (setq titleblock (strcat titleblockfolder "A4_Landscape_test.dwg"))) ((eq size "A4-P") (setq titleblock (strcat titleblockfolder "A4_Portrait_test.dwg"))) ) (if (and titleblock (findfile titleblock) (numberp scale)) (progn (setvar 'expert 2) (setvar 'cmdecho 0) (setvar 'attreq 0) (command "-insert" titleblock (list 0 0 0) scale scale 0) (command "_.explode" "_L") (command "-purge" "B" "YourBlockName" "N") (command "._zoom" "e") ) (alert "Unable to insert titleblock") ) ) ) (princ) ) ; example1 (setq choise (CycleList "Choose titleblock size" '("A0" "A1" "A2" "A3" "A4"))) ; example2 (setq choise (CycleList "Choose titleblock scale" '(1 10 50 100))) (defun CycleList (msg lst / inp loop rtn) (setq loop t) (while loop (princ "\nCycle list with tab or L-mouse / accept use enter,space or R-mouse / Esc or x for exit\n") (princ (strcat "\r" msg " <" (vl-princ-to-string (car lst)) "> : ")) (setq inp (vl-catch-all-apply 'grread (list nil 8 0))) (if (vl-catch-all-error-p inp) (progn (princ "\nTitleblock insertion cancelled")(setq rtn nil loop nil)) (progn (cond ;tab ((or (equal inp '(2 9))(= (car inp) 3)) (setq lst (append (cdr lst)(list (car lst)))) (princ (strcat "\r" msg " <" (vl-princ-to-string (car lst)) "> : "))) ;enter,space,r-mouse ((or (equal inp '(2 13)) (equal inp '(2 32))(= (car inp) 25)) (setq rtn (car lst) loop nil)) ;x or X ((member inp '((2 88)(2 120)))(setq rtn nil loop nil)) ) ) ) ) (terpri) rtn ) ; start command with (c:Captain_Ahap) well , (work)day is done , so I'm gone ... with the wind (or the waves since you're obviously have a fishy thing ;-) gr. Rlx Thank you rlx.It works nice. will be using the 'support' folder in c instead of temp. Quote
