So I have my settings a certain way, and I havw a lisp routine that I am able to type a command to set them all back to a certain way. But for some reason when I am in a command it works and then when I exit the command or hit ESC, prior to completing the command, all my settings go wakko! For example my osnap settings turn off, my polar settings go from what I have set (15 degrees) and then it changes it by 2.5 degrees. orthodox sometimes turns off or on.
Does anyone know of a fix for this? Or a better work around? It seems to happen almost each time I run a command.
Thanks all
Post the code, in code tags, in the lisp forum. It sounds like you are bypassing the reset routine by quitting the lisp early.
i have posted the code here.
http://www.cadtutor.net/forum/showthread.php?104633-osmode-is-changing-on-me-or-the-reset-is-being-bypassed&p=704538#post704538
