What I am saying is run full code and if it errors then post all the commands so we can see error message.
Any else one out there tried it ? Its a smart dynamic block, we may have a use for something similar.
  • Replies 22
  • deejaydave
    12
  • BIGAL
    10
  • harshad
    1
I have managed to get it to work. I edited the 1st lot of code you sent, I deleted the following lines:
(setq fname (open "P:\\Autodesk\\lisp\\civilcad6layercodes.txt" "r"))
and
(foreach att (vlax-invoke obj 'getattributes)
(if (= "ANGLE" (strcase (vla-get-tagstring att)))
(vla-put-textstring att ang)
I then saved the file as a new name, ran it and it worked.
The original angle was the “Dip Direction”, which affects the rotation of the block, I have now been asked to add the “Dip Angle”, which has no effect on the block, it just adds a text box with the angle, my question is this “Would I be able to add this new element to the code, based on what is already there?”.
I would like to than you for all the help you have given me, I think I need to learn a little more about lisp.
