Hi all,
I have a script taken from here which I've tweaked to get the count.
(defun C:XREFCNT (/ i x)
(setq i 0)
(vlax-for x
	(vla-get-blocks
		(vla-get-ActiveDocument (vlax-get-acad-object))
	(if (eq (vla-get-IsXref x) :vlax-true)
		(setq i (1+ i))
i
XREFCNT returns the number in the commandline.
How do I then do an alert, the code below doesn't work. It errors with:
error: bad argument type: fixnump: #
(if XREFCNT > 0)
(alert
(strcat "Number of External Reference Drawings = " (itoa (strcat XREFCNT)))
The command XREFCNT is defined as '#'.
Change this:
To:
(itoa (strcat (XREFCNT)))
And change
To:
(defun XREFCNT (/ i x)
   (if (> (setq c (XREFCNT)) 0)
    (alert (strcat "Number of External Reference Drawings = " (itoa c)))
Thanks to both of you.
Here's the working code.
(setq i 0)
(vlax-for x
	(vla-get-blocks
		(setq i (1+ i))
i
; SETS XREF PATHS TO "RELATIVE" IF IN DRAWING
	; (alert (strcat "Number of External Reference Drawings = " (itoa c)))
	(command "-XREF" "T" "*" "R")
You can use C:xrefcnt but defun call has to match (c:xrefcnt)
Is there a reason for IF to be outside the defun ?
(defun c:XREFCNT2 (/ i x)
(setq i 0)
	(vlax-for x
	(vla-get-blocks
		(setq i (1+ i))
(if (> i 0)
	(alert (strcat "Number of External Reference Drawings = " (rtos i 2 0)))
	(alert "No Xrefs")
(c:XREFCNT2)
Because I have this below to use the redir command. And I call it elsewhere in the startup script.
(if
(vl-string-search "company_name_here" (strcat(getvar 'dwgprefix)))
		(Command ".script" "XRef_company_name_here_Paths_Fix.scr")
	(setq StyleSheet "company_name_here.ctb")
