Please somebody can help me in a little issue ?
I'm trying to have an excel interface in order to write some drawing blocks attribute excration.
Here below code:
Dim NUOVA_ISTANZA As Object
Dim WRKB As Workbook                                                    ' Attribuzione della variabile "Cartella di lavoro Excel"
Dim WRKS As Worksheet                                                   ' Attribuzione della variabile "Foglio di lavoro"
On Error GoTo MESSAGGIO_ERRORE
Set NUOVA_ISTANZA = GetObject(, "Excel.Application")                    ' Attribusce alla variabile "NUOVA_ISTANZA" l'applicazione Excel: se Excel non è aricatot restituisec un errore
Set WRKB = NUOVA_ISTANZA.Workbooks.Add                                  ' Attribuisce alla variabile WRKB la cartella di lavoro Excel corrente
Set WRKS = NUOVA_ISTANZA.ActiveSheet
Now, I got an error message on WRKB As Workbook instruction "User defined type not defined".
If I continue without variable dim, later when I'm trying to set an excel sheet formatting as border and other cells formatting
With WRKS.Columns(2).Resize(, 3)                                                            ' Bordo destro e sinistro colonne coordinate
   .Borders(xlEdgeLeft).LineStyle = xlContinuous
   .Borders(xlEdgeRight).LineStyle = xlContinuous
   .Borders(xlInsideVertical).LineStyle = xlContinuous
End With
I got an error "Application-defined or object-defined error"
Please help me
  • 4 months later...
Hello!
You need firstly to set a excel reference, so you will get manipulate what you want.
Let's try help with a litle example:
This error "Application-defined or object-defined error" is typical ausency of the object.
