dhananjay567 Posted June 24, 2018 Posted June 24, 2018 os windows 10 updated to Windows 10 pro. externalreferences command is not working in autocad 2014 LT. please advice Quote
Dana W Posted June 24, 2018 Posted June 24, 2018 No Autocad older than 2016 is supported on Windows 10. There will be issues. You may have to resort to a compatibility interface software such as Longbow. Quote
pendean Posted June 25, 2018 Posted June 25, 2018 http://www.longbowsoftware.com have free tips to try, but if they do not work, you can purchase their fix for your old software in Win10. Quote
rkmcswain Posted June 25, 2018 Posted June 25, 2018 (edited) Perhaps the palette is just off your screen. There is no compatibility issue with Windows 10 and the ACAD 2014 Xref palette. Source: We are running many Win 10 boxes with 2014 installed. Does the command CLASSICXREF work? Edited June 25, 2018 by rkmcswain Add more detail. Quote
addysmith97 Posted September 7, 2018 Posted September 7, 2018 I think you should Reset settings to default. When you updated your windows, you must reset settings to default. Maybe its work for you. Quote
