Greg123 Posted June 21, 2018 Posted June 21, 2018 Dear Members, I have some stretchable dynamic Blocks. I would like to insert and change the length of them in command line. (without use my mouse and grip points) i havent got any problem with the insertation but i cant change the length of this bloks without using mouse. in Properties window there is a section (custom) where i can change the length of the blocks but when i type in command line: change-properties, there i cant find it. just the following options: color, elev, layer, ltype, ltscale, lweight thickness, transparency, materia, annotative Do you have any idea, how could i manage this problem? thanks your answer Quote
