sarahwestcott Posted June 17, 2018 Share Posted June 17, 2018 Hi, Newbie here, whenever I use push/pull or extrude the wall I make is gridded. I would rather not see this grid, every tutorial online has clean wireframe walls without grids on them. How do make it go away?! Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 18, 2018 Share Posted June 18, 2018 Attach a copy of the drawing in question to your next post and someone here will take a look at it. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted June 18, 2018 Share Posted June 18, 2018 I have moved your thread to the AutoCAD 3D Modelling & Rendering Forum. Are they surfaces or 3d Solids? Like mentioned, post a drawing with one of the walls. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted June 18, 2018 Share Posted June 18, 2018 (edited) Welcome to CADTutor sarah. It sounds like you may be extruding polylines or linework which is not CLOSED, resulting in surfaces, instead of 3D Solid objects. PRESSPULL is much more forgiving, and doesn't require CLOSED polylines, as it generates a REGION, which is then used in the command, and should CREATE a true 3D Solid, unless you start the command on a surface. You would do well to explore the POLYSOLID command, try it you'll like it. Good point ReMark PRESSPULL it is, I forget the name because I use ppp as my alias for it. It seemed odd to me that such a thing was happening when using it, whence my clarification of how it works, and the lack of CLOSED polyline requirement. Sarah, watch this link from the Tutorials page on CADTutor, it will probably help you come to grips with some modeling basics. http://www.cadtutor.net/tutorials/autocad/extrude-and-press-pull/ There are other good resources available there, as well. Edited June 19, 2018 by Dadgad Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 18, 2018 Share Posted June 18, 2018 I believe the OP did reference the use of Push/Pull in the first post. BTW...it's PRESSPULL. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted June 18, 2018 Share Posted June 18, 2018 From AutoCAD Help. Selection Presspull behavior Open 2D object (such as an arc) Extrudes to create a surface Closed 2D object (such as a circle) Extrudes to create a 3D solid Inside a bounded area Extrudes to create a 3D solid 3D solid face Offsets the face, expanding or condensing the 3D solid Quote Link to comment Share on other sites More sharing options...
sarahwestcott Posted June 19, 2018 Author Share Posted June 19, 2018 I was trying to create a vertical plane by extending one of the horizontal lines, but the plane has that lattice on it that I don't want. Thank you for the suggestions, I'll start there and see if I can make any of them work. Quote Link to comment Share on other sites More sharing options...
Cad64 Posted June 19, 2018 Share Posted June 19, 2018 Extruding a line creates a surface, not a solid. That's why you're seeing that lattice. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted June 20, 2018 Share Posted June 20, 2018 Extruding a line creates a surface, not a solid. That's why you're seeing that lattice. +1 In a nut shell. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted June 20, 2018 Share Posted June 20, 2018 Extruding a line creates a surface, not a solid. That's why you're seeing that lattice. PRESSPULL (unless they make a bounded area), EXTRUDE, SWEEP on non-closed objects make surfaces AFAIK. If using Hidden or shaded view, etc. the lattice will not be seen. Alternately, if these are lines, you can change the thickness property in the properties palette and the lattice will not show. Why not post a drawing? Quote Link to comment Share on other sites More sharing options...
odachek Posted July 17, 2018 Share Posted July 17, 2018 How about create a thin rectangular box and extrude instead of drawing a line? Quote Link to comment Share on other sites More sharing options...
