gmmdinesh Posted June 13, 2018 Share Posted June 13, 2018 Hi Everyone. I have Lisp file to make double offset, offset distance are getting automatically as per lisp. but i want enter that distance manually and that entered value will be taken as offset distance. Please anyone tell me how to change this. (defun c:oly (/ l s p e) (command ".undo" "m") (command "-layer" "M" "DELETE-LAYER" "c" "green" "DELETE-LAYER" "" "") (setq l (entlast)) (if (tblsearch "LAYER" "DELETE-LAYER") (while (and (setq s (car (entsel "\nPick Line/Polyline to offset :"))) (wcmatch (cdr (assoc 0 (entget s))) "LINE,*POLYLINE") (setq p (getpoint "\nSpecify offset side :")) ) (foreach x '((1.25 6) (1.75 3)) (command "_.offset" (car x) (ssadd s) "_non" p "") (and (not (= (setq e (entlast)) l)) (entmod (append (entmod (subst '(8 . "DELETE-LAYER") (assoc 8 (entget e)) (entget e) ) ) (list (cons 62 (cadr x))) ) ) (setq l e) ) ) ) (alert "Layer name <DELETE-LAYER> is not found in drawing <!>.") ) (princ) ) Thanks in Advance Quote Link to comment Share on other sites More sharing options...
Emmanuel Delay Posted June 13, 2018 Share Posted June 13, 2018 So, now that distance is here: (foreach x '((1.25 6) (1.75 3)) first offset: distance: 1.25, color: 6 second offset: distance: 1.75, color: 3 Do you still want 2 lines? What about those colors? Quote Link to comment Share on other sites More sharing options...
gmmdinesh Posted June 13, 2018 Author Share Posted June 13, 2018 Yes still i need to offset two lines both are coming with different colours.. Right now i want to enter the offset distance manually. Quote Link to comment Share on other sites More sharing options...
Emmanuel Delay Posted June 13, 2018 Share Posted June 13, 2018 (setq offsetdistance 0.0) ;; just to remember it next time (setq offsetdistance2 0.0) ;; just to remember it next time (defun c:oly (/ l s p e x prompt data) (if (> offsetdistance 0.0) (setq prompt (strcat "\nEnter distance 1 <" (rtos offsetdistance 2 2) ">: ")) (setq prompt "\nEnter distance 1: ") ) (if (setq x (getreal prompt)) (setq offsetdistance x) ) (if (> offsetdistance2 0.0) (setq prompt (strcat "\nEnter distance 2 <" (rtos offsetdistance2 2 2) ">: ")) (setq prompt "\nEnter distance 2: ") ) (if (setq x (getreal prompt)) (setq offsetdistance2 x) ) (setq data (list (list offsetdistance 6) (list offsetdistance2 3) )) (command ".undo" "m") (command "-layer" "M" "DELETE-LAYER" "c" "green" "DELETE-LAYER" "" "") (setq l (entlast)) (if (tblsearch "LAYER" "DELETE-LAYER") (while (and (setq s (car (entsel "\nPick Line/Polyline to offset :"))) (wcmatch (cdr (assoc 0 (entget s))) "LINE,*POLYLINE") (setq p (getpoint "\nSpecify offset side :")) ) (foreach x data (command "_.offset" (car x) (ssadd s) "_non" p "") (and (not (= (setq e (entlast)) l)) (entmod (append (entmod (subst '(8 . "DELETE-LAYER") (assoc 8 (entget e)) (entget e) ) ) (list (cons 62 (cadr x))) ) ) (setq l e) ) ) ) (alert "Layer name <DELETE-LAYER> is not found in drawing <!>.") ) (princ) ) If you want different colors, change the 6 and the 3 in these lines: (setq data (list (list offsetdistance 6) (list offsetdistance2 3) )) Quote Link to comment Share on other sites More sharing options...
BIGAL Posted June 13, 2018 Share Posted June 13, 2018 I am going to say I did not look to closely will try to find I did a offset routine that just allowed like a csv as input 3,2,-3,-2 so end up with 4 lines +/ve I guess could add color also. Somethings just write and post and dont really save then this happens can not find. This is not what I was looking for but a simple offset you can enter -ve to go other side. (defun C:MULOFF ( / obj s off) (vl-load-com) (setq obj (entsel "\nSelectObject")) (setq s (getpoint "\nPick Offset side")) (while (/= (setq off (getreal "\nEnter offset or Enter to exit")) nil) (vl-cmdf "_.offset" off obj s "") (setq obj (entlast)) ) ) (c:muloff) If you want change layer (setq obj (entlast)) (chprop obj "la" "delete-layer" "") Quote Link to comment Share on other sites More sharing options...
gmmdinesh Posted June 13, 2018 Author Share Posted June 13, 2018 Thank you so much Emmanuel, It's working perfectly. One more Help, I want to offset two more lines (total 4 lines) with different distances, Please tell me how to change the lisp. Quote Link to comment Share on other sites More sharing options...
Emmanuel Delay Posted June 13, 2018 Share Posted June 13, 2018 4 lines: (setq offsetdistance 0.0) ;; just to remember it next time (setq offsetdistance2 0.0) ;; just to remember it next time (setq offsetdistance3 0.0) (setq offsetdistance4 0.0) (defun c:oly (/ l s p e x prompt data) (if (> offsetdistance 0.0) (setq prompt (strcat "\nEnter distance 1 <" (rtos offsetdistance 2 2) ">: ")) (setq prompt "\nEnter distance 1: ") ) (if (setq x (getreal prompt)) (setq offsetdistance x) ) (if (> offsetdistance2 0.0) (setq prompt (strcat "\nEnter distance 2 <" (rtos offsetdistance2 2 2) ">: ")) (setq prompt "\nEnter distance 2: ") ) (if (setq x (getreal prompt)) (setq offsetdistance2 x) ) (if (> offsetdistance3 0.0) (setq prompt (strcat "\nEnter distance 3 <" (rtos offsetdistance3 2 2) ">: ")) (setq prompt "\nEnter distance 3: ") ) (if (setq x (getreal prompt)) (setq offsetdistance3 x) ) (if (> offsetdistance4 0.0) (setq prompt (strcat "\nEnter distance 4 <" (rtos offsetdistance4 2 2) ">: ")) (setq prompt "\nEnter distance 4: ") ) (if (setq x (getreal prompt)) (setq offsetdistance4 x) ) (setq data (list (list offsetdistance 6) (list offsetdistance2 3) (list offsetdistance3 4) (list offsetdistance4 5) )) (command ".undo" "m") (command "-layer" "M" "DELETE-LAYER" "c" "green" "DELETE-LAYER" "" "") (setq l (entlast)) (if (tblsearch "LAYER" "DELETE-LAYER") (while (and (setq s (car (entsel "\nPick Line/Polyline to offset :"))) (wcmatch (cdr (assoc 0 (entget s))) "LINE,*POLYLINE") (setq p (getpoint "\nSpecify offset side :")) ) (foreach x data (command "_.offset" (car x) (ssadd s) "_non" p "") (and (not (= (setq e (entlast)) l)) (entmod (append (entmod (subst '(8 . "DELETE-LAYER") (assoc 8 (entget e)) (entget e) ) ) (list (cons 62 (cadr x))) ) ) (setq l e) ) ) ) (alert "Layer name <DELETE-LAYER> is not found in drawing <!>.") ) (princ) ) Quote Link to comment Share on other sites More sharing options...
hanhphuc Posted June 14, 2018 Share Posted June 14, 2018 (edited) 4 lines: (setq data (list (list offsetdistance 6) (list offsetdistance2 3) (list offsetdistance3 4) (list offsetdistance4 5) )) hi, FWIW prompt is a protective symbol. my $0.05 (setq str .. ) instead of (setq prompt (getstring )) another, my suggestion for multiple getreal it accepts zero & negative, you can modify to suit you (defun _getreal (msg lst / np str l ) ;hanhphuc (while (not np ) (setq str (getstring t (strcat msg " " (vl-string-translate "()" " |" (vl-princ-to-string (mapcar '(lambda (x) (strcat "|" (rtos x 2))) lst)) ) " ? : " ) ) l (cond ((read (strcat "(" str ")"))) (lst) ) np (if (and l (vl-every 'numberp l)) l (prompt "\nOops! Invalid value !!") ) ) ) l ) Example: (setq A (_getreal "\nEnter multiple offset distance," [color="blue"]nil[/color] )) Enter multiple offset distance, nil ? : 1 2 3 4 5 [color="green"];<--user input separate by space [/color] (1 2 3 4 5) (setq B (_getreal "\nEnter multiple offset distance," A )) Enter multiple offset, |1 |2 |3 |4 |5| ? : [color="green"]; <Enter> to accept default values[/color] (1 2 3 4 5) ;from your test (setq [color="red"]data[/color] (_getreal "\nEnter multiple offset distance," B )) Enter multiple offset, |1 |2 |3 |4 |5| ? : [b]6 3 4 5[/b] [color="green"];<--user overrides default[/color] (6 3 4 5) [color="green"];data to be used [/color] (foreach [b]x[/b] [color="red"]data[/color] [color="green"]; offset [b]x[/b] bla bla [/color] ) Edited June 14, 2018 by hanhphuc _prompt to _getreal Quote Link to comment Share on other sites More sharing options...
BIGAL Posted June 14, 2018 Share Posted June 14, 2018 (edited) hahnphuc basicly the same as I suggested but csv style still loooking when you have so many hard to remember where you put the code some times. for fun the bla bla (defun c:muloff(/ o s l) (setq o (entsel "\nSelect Object")) (setq pt (getpoint "\nPick Offset side")) (setq data (_prompt "\nEnter multiple offset distance," B )) (foreach i data (vl-cmdf "_.offset" i o pt "") ) ) Edited June 14, 2018 by BIGAL Quote Link to comment Share on other sites More sharing options...
hanhphuc Posted June 14, 2018 Share Posted June 14, 2018 hahnphuc basicly the same as I suggested but csv style still loooking when you have so many hard to remember where you put the code some times. yeah BIGAL, csv is good solution too i just offer generic suggestion rather than @Emmanuel Delay to rewrite his code if OP request more offsets Quote Link to comment Share on other sites More sharing options...
Emmanuel Delay Posted June 14, 2018 Share Posted June 14, 2018 Thanks guys Quote Link to comment Share on other sites More sharing options...
Emmanuel Delay Posted June 14, 2018 Share Posted June 14, 2018 When using csv as a data import/export, have you guys found a way for Excel to not turn entity handle 34E57 in 34*10^57, and not omit all the leading zeros, not turn things into dates, ... I know, it's not Autocad or LISP's fault, but maybe you found some obvious solution... I can't explain to my colleagues how to import it in excel, set the data formatting, (Meanwhile I use notedpad++ to adapt data in the csv) ... Quote Link to comment Share on other sites More sharing options...
hanhphuc Posted June 14, 2018 Share Posted June 14, 2018 hi, do you notice command : ATTOUT , 'handles' output with quote mark, i.e: '34E57 Quote Link to comment Share on other sites More sharing options...
hanhphuc Posted June 14, 2018 Share Posted June 14, 2018 hahnphuc basicly the same as I suggested but csv style still loooking when you have so many hard to remember where you put the code some times. for fun the bla bla (defun c:muloff(/ o s l) (setq o (entsel "\nSelect Object")) (setq pt (getpoint "\nPick Offset side")) (setq data ([color="blue"]_getreal[/color] "\nEnter multiple offset distance," [color="red"][b]B[/b][/color] )) (foreach i data (vl-cmdf "_.offset" i o pt "") ) ) sorry BIGAL i've changed the symbol _prompt to _getreal which naming is more relevant Although global variable is not preferable than csv , another suggestion - store as 'list' string (setvar '[b][color="purple"]users1[/color][/b] (vl-princ-to-string [color="red"]'(1 2 3 4 5)[/color])) [color="green"]; as default[/color] or (_getreal "msg" nil) (setq [b][color="red"]B[/color][/b] (read (getvar '[b][color="purple"]users1[/color][/b]))) Quote Link to comment Share on other sites More sharing options...
gmmdinesh Posted June 14, 2018 Author Share Posted June 14, 2018 Thank you so much.. All of you for your code. Thank Emmanuel..... code was worked perfectly. Quote Link to comment Share on other sites More sharing options...
