simple area
bogeymen77
i'm looking for a simple area routine base on the dimension not the line.
i want to be able to click on 2 cotation that i got from the dimlinear command and have the area "print" in a text format where i want to.
I know a routine with a lot of visual lisp routine in it, but i'm looking a version with a standard/ basic lisp.
thank you.
Hi,
Is it something like select the 1st dimlinear then the 2nd one then specify a point to place the area as a text object which supposed to be produced from multiplying of dim text1 and dim text2 ?
This?
(defun c:Test ( / dm1 dm2 en1 en2 obj get hgt ins )
 (and
   (setq dm1 (car (entsel "\nSelect 1st dimlineaer :")))
   (or (member '(100 . "AcDbAlignedDimension") (setq en1 (entget dm1)))
       (alert "Invalid object.<!>")
   (setq dm2 (car (entsel "\nSelect 2nd dimlineaer :")))
   (or (member '(100 . "AcDbAlignedDimension") (setq en2 (entget dm2)))
   (setq obj (tblobjname "BLOCK" (cdr (assoc 2 en1))))
   (while (and (not hgt) (setq obj (entnext obj)))
     (and (= (cdr (assoc 0 (setq get (entget obj)))) "MTEXT")
          (setq hgt (assoc 40 get))
   (setq ins (getpoint "\nSpecify location of text area :"))
   (entmake (list '(0 . "TEXT") (cons 10 (trans ins 0 1)) (cons 11 (trans ins 0 1)) hgt
                  (cons 1 (rtos (* (cdr (assoc 42 en1)) (cdr (assoc 42 en2))) 2))
exactly. i'll try your code.
work perfectly thank...
If i can ask you an other issue.
if i have a few area measurement and i want to have the total, what would be the routine/formula?
thank
You're welcome.
Do you mean that you would like to sum texts with numerical values to new text as total areas?
yes. for exemple i got 4 piece of counter top ,i got the area for each one. After i would like to have the sum of all 4 pieces.
thank you
What do you mean by counter top?
Can you upload a sample drawing showing the outcome of the process that you looking forward?
I am sure Tharwat will continue to answer there are a few different ways to do this.
1 Pick text and add up.
2 Select text on one layer, your dwg its on layer 0 needs to be something different, like table-area.
3 Make a block and have an attribute then just total all attributes.
4 like 3 but make an Autocad table of the areas with common table top styles.
It would be good at this point to suggest which method you want so its not a case of multiple changes.
Could not resist suggestion 1, this is real basic no error checking.
(defun c:test ( / tot ent obj)
(setq tot 0.0)
(while (setq ent (entsel "\nPick text Enter to stop"))
(setq obj (vlax-ename->vla-object (car ent)))
(setq tot (+ (atof (vla-get-textstring obj)) tot))
(alert (strcat "The total area is = " (rtos tot 2 3 )))
(defun c:sum (/ int tot sel ent int val ins)
 ;; Tharwat -  Date: 09.Jun.2018	;;
 (princ "\nSelect text areas to sum :")
 (and (setq int -1
            tot 0.0
            sel (ssget "_:L" '((0 . "TEXT")))
        (while (setq ent (ssname sel (setq int (1+ int))))
          (and (numberp (setq val (read (cdr (assoc 1 (entget ent))))))
               (setq tot (+ tot val))
        (< 0.0 tot)
      (setq ins (getpoint "\n Specify text location :"))
                     (cons 40 (getvar 'TEXTSIZE))
                     (cons 1 (rtos tot 2))
works Perfectly !!! WOW thanks you all !!!
You're welcome.
Nicely done Tharwat. Maybe 1 little suggestion.
(cons 1 (strcat "Area = " (rtos tot 2)))
Thank you BIGAL. :)
Yes indeed it is a very good suggestion and make sense.
