hi~ Properties window disappeared, help me.
hi~
i'm using Autocad 2012 version.
I used properties window Left anchored.
but now Properties window disappeared.
i try to command .
command : ch
command : properties
command : mo
ctrl+1
any command not availible. help me. thank you.
Did you try minimizing the AutoCAD window to see if the Properties palette is hiding behind it?
