Hellow~ , Would you see this message. about this AutoLisp .
Marko_ribar
I know this was originally written by Lee Mac and I'm not trying to take that away from him I just modified to work for what I need it for but I need some help. If someone could help me I would appreciate it look at the comment in red.
(defun c:segoff ( / a b d e i l n p s v x y z )
(setq [color="red"]obj [/color](vl-catch-all-apply 'vlax-invoke (list VlaObj 'explode))) [color=red];;; I'm trying to figure out how to collect the lines this creates to use on the next step[/color]
(setq objLst(mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr(ssnamex [color="red"]obj[/color])))))
hi, IMO Lee's code is fine. not sure what's your idea ?
[color="green"];;ignore this line [/color]
;;; (setq objLst (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex obj)))))[color="red"] ; <-- error ; (ssnamex ss ) selection set , not vla-object [/color]
[color="green"];;This is sufficient[/color]
(setq [color="red"][b]objLst[/b] [/color](vl-catch-all-apply 'vlax-invoke (list VlaObj 'explode))) [color="green"];;; vla-explode will returns a list [/color]
@Marko - try testing revision cloud it offsets inside.
  • Replies 26
  • marko_ribar
    8
  • nest1291
    7
  • BrianTFC
    4
  • hanhphuc
    4
Posted Images
Thanks guys for your input. Hanhphuc's idea worked perfectly as soon as I erased that line it extended my line to the end of the outside blue line like I needed. thanks again.
Create new layer and make it current, also change current color to what you desire and finally apply this revision :
;; arc offset is always in direction so that new arc is larger than its reference arced segment of lwpolyline
(defun c:offs ( / LM:listclockwise-p xy ob s d i l cc )
 (vl-load-com)
 ;; List Clockwise-p - Lee Mac
 ;; Returns T if the point list is clockwise oriented
 (defun LM:listclockwise-p ( lst )
   (minusp
     (apply '+
       (mapcar
         ''(( a b ) (- (* (car b) (cadr a)) (* (car a) (cadr b)))
         lst (cons (last lst) lst)
 (vl-cmdf "_.UNDO" "_BEGIN")
 (prompt "\nSelect closed lwpolylines...")
 (and (setq s (ssget '((0 . "LWPOLYLINE") (-4 . "&=") (70 . 1))))
   (progn (initget 7)
     (setq xy '(( l )(if l (cons (list (car l)(cadr l)) (xy (cddr l)))))
            d (getdist "\nPick or specify offset : ")
           cc (getvar 'cecolor)
   (repeat (setq i (sslength s))
     (setq ob (vlax-ename->vla-object (ssname s (setq i (1- i))))
            l (xy (vlax-get ob 'coordinates))
     (mapcar
       ''(( x )
         (mapcar
           ''(( f / o ) (setq f (eval (read (strcat "vlax-curve-get" f)))
                              o (vlax-invoke x 'offset
                                  ( (if (LM:listclockwise-p l)
                                    d
                        (entmake (list '(0 . "LINE") (cons 10 (f x)) (cons 11 (f (car o)))))
                        (entupd (cdr (assoc -1 (entmod (subst (cons 8 (getvar 'clayer)) (assoc 8 (entget (vlax-vla-object->ename (car o)))) (entget (vlax-vla-object->ename (car o))))))))
                        (cond
                          ( (= cc "BYLAYER")
                            (vl-cmdf "_.CHANGE" (vlax-vla-object->ename (car o)) "" "_P" "_C" "BYLAYER" "")
                          ( (= cc "BYBLOCK")
                            (vl-cmdf "_.CHANGE" (vlax-vla-object->ename (car o)) "" "_P" "_C" "BYBLOCK" "")
                          ( (and (> (strlen cc) 4) (= (substr cc 1 3) "RGB"))
                            (vl-cmdf "_.CHANGE" (vlax-vla-object->ename (car o)) "" "_P" "_C" "_T" (substr cc 5) "")
                          ( t
                            (vl-cmdf "_.CHANGE" (vlax-vla-object->ename (car o)) "" "_P" "_C" cc "")
           '("startpoint" "endpoint")
         (vla-erase x)
       (vlax-invoke ob 'explode)
     ) ;mapcar
   ) ;repeat
 ) ;and
 (vl-cmdf "_.UNDO" "_END")
Note that now you don't need (LM:defaultprops)...
HTH., M.R.
hi ~ thank you for your help.
i have one more question ~
i use this lisp . very good. changed layer thannk. you.
but after it worked . it makes double line outside.
How can i fix it ?
Thanks for checking, I haven't noticed it... Try this quick fix :
 (vl-load-com)
   (minusp
     (apply '+
       (mapcar
   (progn (initget 7)
     (mapcar
       ''(( x )
         (mapcar
                                    d
                        (cond
                          ( (= cc "BYLAYER")
                          ( (= cc "BYBLOCK")
                          ( t
                        )[color=red]
                        (if (eq f (eval (read (strcat "vlax-curve-getendpoint"))))
                          (vla-erase (car o))
                        )[/color]
         (vla-erase x)
     ) ;mapcar
   ) ;repeat
 ) ;and
 (vl-load-com)
   (minusp
     (apply '+
       (mapcar
   (progn (initget 7)
     (mapcar
       ''(( x )
         (mapcar
                                    d
                        (cond
                          ( (= cc "BYLAYER")
                          ( (= cc "BYBLOCK")
                          ( t
                        )[color=red]
                          (vla-erase (car o))
                        )[/color]
         (vla-erase x)
     ) ;mapcar
   ) ;repeat
 ) ;and
Thank you very much !!!!!!!!!!!!!!! very useful. to me. . thank you~
BTW. You have to apply this fix to all hanhphuc's versions...
M.R.
M.R.
Thanks. Marko for the fix :)
(if (eq f vlax-curve-getendpoint))))
           (vla-erase (car o))
v1.1 known bugs :ouch:
1.S-shape curve
2.reversed revision cloud
