Hello All,
I am trying to remove one table from my drawings. Please take a look at the attached sample dwg. I have over 8000 drawings to modify. All drawings contains 3 tables as shown in sample drawing.
I want to erase table 3. The location of the table 3 can be anywhere in with in outside border.
tried many things. but no luck so far.
right now i have an autolisp that works fine if i run it in one drawing. but it doesn't work while running thru script.
(defun c:abcd()
(setq ss1 (ssget))
(command "erase" "p" "" )
(command "zoom" "e" "")
(command "qsave")
i have a scrip that loads the autolisp containing the above code.
any help would be really appreciated.
TEST DWG.dwgFetching info...
If its a table with 4 columns can be done. A word of warning this is destructive once saved table is gone. I would test on a few that have been copied. I would back them all up 1st.
(defun AH:deltable ( / x y)
(setvar 'ctab "Model")
(setq y 4)
(setq ss (ssget "X" (list (cons 0 "ACAD_TABLE"))))
(setq obj (vlax-ename->vla-object(ssname ss (setq x (- x 1)))))
(setq cols (vla-get-Columns obj))
(if (= cols Y)(vla-delete obj))
(AH:deltable)
open dwg1 (load "deltable") close Y
open dwg2 (load "deltable") close Y
open dwg3 (load "deltable") close Y
Hi Bigal,
Thank you very much for the reply. It works like a charm.
the only thing i noticed is that your code works when i have a table with 4 columns. Is there a way to modify the code to delete the table with 4 or more rows.?
Thank you once again.
I have modified your code to following code & it works like a charm.
(setq x 4)
(repeat (setq y (sslength ss))
(setq obj (vlax-ename->vla-object(ssname ss (setq y (- y 1)))))
(setq rows (vla-get-Rows obj))
(if (>= rows x)(vla-delete obj))
(AH:deltable)
Thank you very much.
