Siberian Posted May 28, 2018 Share Posted May 28, 2018 When I link models or dwg-files from architects they are often aligned so that north faces straight up on the screen. This often creates weird drafting angles, and so I wonder how I can align certain views so that they appear perpendicular to the screen. Naturally I can't just use the align command as that would create collaboration issues. I've read alot about work planes, and that's where the solution seems to be, but I'm still not able to get it right. Could someone please nudge me in the right direction? Quote Link to comment Share on other sites More sharing options...
guran Posted May 28, 2018 Share Posted May 28, 2018 Use UCS/OBject to orient your UCS after a line you want horizontal on the screen, then type "plan" followed by ENTER. Quote Link to comment Share on other sites More sharing options...
Siberian Posted May 28, 2018 Author Share Posted May 28, 2018 Use UCS/OBject to orient your UCS after a line you want horizontal on the screen, then type "plan" followed by ENTER. That certainly would do the trick if we we're talking about AutoCAD Quote Link to comment Share on other sites More sharing options...
BIGAL Posted May 29, 2018 Share Posted May 29, 2018 https://www.revitforum.org/architecture-general-revit-questions/12590-changing-view-orientation-similar-autocads-ucs-function-possible.html Quote Link to comment Share on other sites More sharing options...
halam Posted May 29, 2018 Share Posted May 29, 2018 That certainly would do the trick if we we're talking about AutoCAD How these @$#% progs not work togehter Autodesk never gets the idea that there might actually be people working with both. Quote Link to comment Share on other sites More sharing options...
tzframpton Posted May 29, 2018 Share Posted May 29, 2018 Crop Regions that are Rotated, or click and rotate the View Boundary to whatever angle you need are two ways you can reorient a view. -TZ Quote Link to comment Share on other sites More sharing options...
