Sengna Posted May 17, 2018 Posted May 17, 2018 I have about 25 paperspace layout that were set at 11x17 size, since the paper size does not matter, I would like to batch plot multiple pages all at once to 8.5x11 size, how can I do that? I could n't find what I m looking for on youtube. any suggestion would be appreciated. Quote
maratovich Posted May 17, 2018 Posted May 17, 2018 Do you need to change the new paper format in all layouts? Quote
pendean Posted May 17, 2018 Posted May 17, 2018 if paper size really doesn't matter, why not PUBLISH to PDF and print away all you want to any size sheet you need, let your PDF viewer APP do the scaling for you. Quote
Sengna Posted May 17, 2018 Author Posted May 17, 2018 maratovich said: Do you need to change the new paper format in all layouts? What do you mean by that? I have 25 layouts (or called Paper space) and I want to batch plot all at once to 8.5x11 size, those 25 layouts were originally set at 11x17 Quote
Sengna Posted May 17, 2018 Author Posted May 17, 2018 pendean said: if paper size really doesn't matter, why not PUBLISH to PDF and print away all you want to any size sheet you need, let your PDF viewer APP do the scaling for you. Good idea, what command to do all to PDF? Quote
profcad Posted May 17, 2018 Posted May 17, 2018 Sengna said: Good idea, what command to do all to PDF? Use the PUBLISH command. Change the Output to PDF. Quote
Sengna Posted May 17, 2018 Author Posted May 17, 2018 profcad said: Use the PUBLISH command. Change the Output to PDF. wow that is awesome, I got the all PDF layout in one file, the only issue I have after converted to PDF is that, most of the border on title block on the right side were missing. is there a way I can set print area then convert to PDF? Quote
BIGAL Posted May 18, 2018 Posted May 18, 2018 I had some similar problems with Publish so wrote a plot multiple layouts to pdf in lisp. If you post a sample dwg with a layout happy to provide a lisp to suit. I would also look more into maratovich as he has a very good universal style plot program I am sure he will provide some more details. Quote
maratovich Posted May 19, 2018 Posted May 19, 2018 I agree with BIGAL. Sengna - Attach your file dwg. Quote
Sengna Posted May 20, 2018 Author Posted May 20, 2018 maratovich said: I agree with BIGAL. Sengna - Attach your file dwg. Bigal and Maratovich, I can't share the drawing due to the confidential Hope you guys understand. Quote
BIGAL Posted May 20, 2018 Posted May 20, 2018 it does not have to be a true dwg just something that shows the typical limits of a layout. In particular if the layouts are different sizes. Quote
tombu Posted May 21, 2018 Posted May 21, 2018 Simply save a copy of the drawing, delete and purge everything in model space and anything confidential and save before attaching here. A smaller file would be preferable and it's just the layout boundary plotting you're concerned with anyway. Quote
