Siberian Posted May 6, 2018 Posted May 6, 2018 I'm not very experienced with Revit, so I just finished som tutorials getting familiar with some of the more typical commands. It involved drafting a small house, but as I am an MEP-engineer I started putting in some ductwork. The issue is that when i look at the house in 3D from the outside, I see the ductwork on the inside. I've tried adjusting hte visual style but that makes no difference. The ducts look different, but I still can see them. If I render the outside view, then it works and everything looks good and real. Can someone point me in the right direction? Quote
welldriller Posted May 7, 2018 Posted May 7, 2018 Not familiar with revit but I would have put my ductwork on a separate layer so that I could freeze it when I did not wat it to show. Quote
tzframpton Posted May 7, 2018 Posted May 7, 2018 I'm not very experienced with Revit, so I just finished som tutorials getting familiar with some of the more typical commands. It involved drafting a small house, but as I am an MEP-engineer I started putting in some ductwork. The issue is that when i look at the house in 3D from the outside, I see the ductwork on the inside. I've tried adjusting hte visual style but that makes no difference. The ducts look different, but I still can see them. If I render the outside view, then it works and everything looks good and real. Can someone point me in the right direction?You are experiencing the effects of the "View Discipline". When you are in a View and nothing is selected, in Properties Palette, you'll see all properties related to the active view. You'll see an option for View Discipline and in the drop down you'll see six different Disciplines: Architectural, Structural, Coordination, Mechanical, Electrical and Plumbing. The three arch/strc/coordination work the same with little differences. They show everything on an "as is" basis with minimal bias to certain elements. The three mech/elec/plmb views, show bias to only the MEP categories and automatically halftone and underlay arch and strc components, which is why you see this "bleed through". Change the View Discipline to one of the non-MEP views and you'll be fine. Coordination Discipline is the most general and shows no bias to any category. More info here: https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/Revit-DocumentPresent/files/GUID-5D8831F6-6F15-4BF3-ACEB-06FBC14A5491-htm.html?st=view%20discipline Hope this helps. -TZ Quote
Siberian Posted May 7, 2018 Author Posted May 7, 2018 Change the View Discipline to one of the non-MEP views and you'll be fine. Coordination Discipline is the most general and shows no bias to any category. I should have been able to stumble upon that one myself, but thanks, that worked great Quote
