Hello...I'm looking for a method or a lisp for "fix the dimension value" in a selected quotes group.
With the properties palette, when I select a single dimenion I can copy the value in the label "modifica locale al testo" (text override in the english version?), so if I scale the dimension the value doesn't change.
Is it possible to do this operation automatically on all the selected dimension?
Regards
Try the following:
(defun c:fixdims ( / ent enx idx sel )
   (if (setq sel (ssget "_:L" '((0 . "*DIMENSION") (1 . "~*?*"))))
       (repeat (setq idx (sslength sel))
           (setq idx (1- idx)
                 ent (ssname sel idx)
                 enx (entget ent)
           (entmod (subst (cons 1 (LM:getdimstring ent)) (assoc 1 enx) enx))
;; Get Dimension String  -  Lee Mac
;; Returns the displayed content of a dimension
(defun LM:getdimstring ( ent / enx rtn )
   (if
       (and
           (setq enx (entget ent))
           (wcmatch (cdr (assoc 0 enx)) "*DIMENSION")
           (setq ent (tblobjname "block" (cdr (assoc 2 enx))))
           (setq ent (entnext ent)
                 enx (entget  ent)
       (while (and ent (null rtn))
           (if (= "MTEXT" (cdr (assoc 0 enx)))
               (setq rtn  (cdr (assoc 1 enx)))
                 enx (entget  ent)
   rtn
Thank you very much! It work's like I need!
