RepCad Posted April 23, 2018 Posted April 23, 2018 hi all, how can i use Boundary command in vba after Getpoint inside a polyline?? i use lisp code : (setq Point (getpoint)) (command "boundary" point "") and i write same code in vba, but it does not work : Pnt = ThisDrawing.Utility.GetPoint(, "Enter a point: ") ThisDrawing.SendCommand "._boundary" & Pnt & vbCr Quote
BIGAL Posted April 23, 2018 Posted April 23, 2018 What does help say about addboundary ? May get around problem also try Bpoly. Quote
smuthuc Posted July 14, 2018 Posted July 14, 2018 :)This will help you Public Sub Draw_Bpoly() Dim p As Variant p = ThisDrawing.Utility.GetPoint(, "First the Point:") ThisDrawing.SetVariable "osmode", 0 ThisDrawing.SendCommand "_.-boundary" & vbCr & "_A" & vbCr & "_I" & vbCr & "_N" & vbCr & vbCr & vbCr & p(0) & "," & p(1) & vbCr & vbCr End Sub enjoy..... Quote
