mit Posted April 10, 2018 Share Posted April 10, 2018 Hello everyone I try to make code to read data from .txt file and fill to object data table in Autocad Map, but it was show ???????? Cloud you please help me? test.txt Chanthaboury.dwg fill_OD_table.lsp Quote Link to comment Share on other sites More sharing options...
hanhphuc Posted April 11, 2018 Share Posted April 11, 2018 Hello everyone I try to make code to read data from .txt file and fill to object data table in ] not sure but just give a try here, sorry if not a good solution Can't display "[color="red"]ດິນບຸກຄົນ[/color]" ? [color="green"];;;(setq remark (vk_ReadTextStream "C:/test.txt" "UTF-8"))[/color] [color="green"];Try alternative way manually copy text from text file then paste[/color] (setq [b]remark[/b] ([color="blue"]getstring [/color] "\nPaste our text here -> ")) [color="green"];"\U+0E94\U+0EB4\U+0E99\U+0E9A\U+0EB8\U+0E81\U+0E84\U+0EBB\U+0E99"[/color] [color="green"];or dialog [/color] (setq [b]remark[/b] (lisped "paste here ") ) Quote Link to comment Share on other sites More sharing options...
mit Posted April 11, 2018 Author Share Posted April 11, 2018 Thank hanhphuc I will try Quote Link to comment Share on other sites More sharing options...
hanhphuc Posted April 16, 2018 Share Posted April 16, 2018 some asian font can be shown normal open function tho it only support ANSI if the initial pair is FE FF (hex) or 254 255 save your test.txt as Unicode (setq f (open path "r")) (setq ret (read-line f))[color="green"] ;<--test only 1st line[/color] (if f (close f)) (defun foo ( str ) ; read unicode - test version hanhphuc 17.04.2018 (apply 'strcat (mapcar ''( ( x ) (apply 'strcat (vl-list* (chr 92) "U+" (mapcar ''( (x / $) (setq $ ( LM:dec->base x 16)) (if (or (< x 10) (=(strlen $)1)) (strcat "0" $) $) ) (reverse x) ) ) ) ) ( '( ( f ) (f (vl-remove-if '(lambda (x) (vl-some '(lambda (y) (= x y) ) '( 254 255 )) ) (vl-string->list str) ) ) ) '( ( l ) (if l (cons (list (car l)(cadr l)) (f (cddr l))) ) ) ) ) ) ) ;; Decimal to Base - Lee Mac ;; Converts a decimal number to another base. ;; n - [int] decimal integer ;; b - [int] non-zero positive integer base ;; Returns: [str] Representation of decimal in specified base (defun LM:dec->base ( n b ) (if (< n b) (chr (+ n (if (< n 10) 48 55))) (strcat (LM:dec->base (/ n b) b) (LM:dec->base (rem n b) b)) ) ) test.. (alert (foo ret ) ) [b][color="red"]ດິນບຸກຄົນ[/color][/b] ?? [color="green"]"\U+0E94\U+0EB4\U+0E99\U+0E9A\U+0EB8\U+0E81\U+0E84\U+0EBB\U+0E99" [/color] Try if the above if working for your language? else plan B: assumed you FSO read stream with UTF-8 file it is more stable but difficult to pair 1~4 bytes, if i have some times Quote Link to comment Share on other sites More sharing options...
mit Posted April 17, 2018 Author Share Posted April 17, 2018 Great!!! It can work Thank you very much hanhphuc and Thank Lee Mac Code Quote Link to comment Share on other sites More sharing options...
hanhphuc Posted April 17, 2018 Share Posted April 17, 2018 (edited) Great!!!It can work Thank you very much hanhphuc and Thank Lee Mac Code you are welcome. hope you will code by yourself next time Here's my UTF-8 functions may be useful in future if you have issue with the previous unicode method. Try it & good luck.. [color="green"];Reference, post#138 ;https://stackoverflow.com/questions/643694/what-is-the-difference-between-utf-8-and-unicode[/color] (defun [color="blue"]UTF8->unicode[/color] ( l / ls 8b d2 foo) ; encode UTF-8 to unicode [color="green"];;;hanhphuc 17.04.2018 [/color] (setq 8b '((s) (while (< (strlen s) (setq s (strcat "0" s))) s) d2 '((str) ;split string to two list (if (> (strlen str) 0) (cons (substr str 1 (d2 (setq str (substr str 9 )))) ) ) foo '(($ / pos i) ; base2 to decimal (setq i 0) (+ (cond ((while (and (> (strlen $) 0) (setq pos (vl-string-search "1" $))) (setq $ (substr $ (+ 2 pos)) i (+ i (expt 2 (strlen $))) ) ) ) (0) ) (atoi $) ) ) ls (mapcar ''((x / $) (setq $ (LM:dec->base (foo x) 16)) (if (= (strlen $) 1) (strcat "0" $) $ ) ) (d2 (apply 'strcat (mapcar ''((a x) (substr (8b a) (- 9 x) x)) l (cdr (assoc (length l) '((1 . (7)) (2 . (5 6)) (3 . (4 6 6)) (4 . (3 6 6 6))))) ) ) ) ) ) (apply 'strcat (vl-list* "\\U" (if (> (length ls) 1) "+" "+00") ls ) ) ) (defun [color="blue"]U8:bytes[/color] (l / x ls) [color="green"];hanhphuc 17.04.2018[/color] ;UTF-8 split the bytes (setq x (car l)) (if l (cons (vl-remove nil (cond ((<= 0 x 191) (setq ls (list x) l (cdr l) ) ls ) ((<= 192 x 223) (setq ls (list x (cadr l)) l (cddr l) ) ls ) ((<= 224 x 239) (setq ls (list x (cadr l) (caddr l)) l (cdddr l) ) ls ) ((<= 240 x 247) (setq ls (list x (cadr l) (caddr l) (cadddr l)) l (cddddr l) ) ls ) ) ) (U8:bytes l) ) ) ) Here's the workaround Step 1: read file ;assume this is the read result from stream UTF-8 file contents (setq ret [b][color="purple"]"Lee Mac & Marko Ribar\r\nHappy Birthday\r\nç¥ä½*们生日快ä¹\r\n幸ç¦\r\nChúc mừng sinh nháº*t\r\n"[/color][/b] ) step 2: convert to char list (setq lst ([color="blue"]vl-string->list[/color] ret)) [color="green"];Decimal [/color] '([color="darkgreen"][b]239 187 191 76 101 101 32 77 97 99 32 38 32 77 97 114 107 111 32 82 105 98 97 114 13 10 72 97 112 112 121 32 66 105 114 116 104 100 97 121 13 10 231 165 157 228 189 160 228 187 172 231 148 159 230 151 165 229 191 171 228 185 144 13 10 229 185 184 231 166 143 13 10 67 104 195 186 99 32 109 225 187 171 110 103 32 115 105 110 104 32 110 104 225 186 173 116 13 10[/color] [/b]) [color="green"];Hex [/color] '([color="purple"]"EF" "BB" "BF" "4C" "65" "65" "20" "4D" "61" "63" "20" "26" "20" "4D" "61" "72" "6B" "6F" "20" "52" "69" "62" "61" "72" "D" "A" "48" "61" "70" "70" "79" "20" "42" "69" "72" "74" "68" "64" "61" "79" "D" "A" "E7" "A5" "9D" "E4" "BD" "A0" "E4" "BB" "AC" "E7" "94" "9F" "E6" "97" "A5" "E5" "BF" "AB" "E4" "B9" "90" "D" "A" "E5" "B9" "B8" "E7" "A6" "8F" "D" "A" "43" "68" "C3" "BA" "63" "20" "6D" "E1" "BB" "AB" "6E" "67" "20" "73" "69" "6E" "68" "20" "6E" "68" "E1" "BA" "AD" "74" "D" "A"[/color] ) ;Step 3: (U8:bytes lst ) function to filter the bytes list '((239 187 191) (76) (101) (101) (32) (77) (97) (99) (32) (38) (32) (77) (97) (114) (107) (111) (32) (82) (105) (98) (97) (114) (13) (10) (72) (97) (112) (112) (121) (32) (66) (105) (114) (116) (104) (100) (97) (121) (13) (10) (231 165 157) (228 189 160) (228 187 172) (231 148 159) (230 151 165) (229 191 171) (228 185 144) (13) (10) (229 185 184) (231 166 143) (13) (10) (67) (104) (195 186) (99) (32) (109) (225 187 171) (110) (103) (32) (115) (105) (110) (104) (32) (110) (104) (225 186 173) (116) (13) (10)) ;Step 4: convert decimal to base 2, then apply the function UTF8->unicode to encode example: 汉 (mapcar ''(( x ) ([color="blue"]LM:dec->base[/color] x 2) )'(230 177 137)) [color="green"];Hex= E6 B1 89 [/color] (alert ([color="blue"]UTF8->unicode[/color] '( [color="purple"]"11100110""10110001""10001001"[/color] ) ) ) [b][color="red"]"\U+6C49"[/color][/b] [color="green"];you can encode each in the byte list, function[/color] [color="blue"] car, last , nth[/color] (UTF8->unicode ([color="blue"]nth[/color] 10 lst) ) Finally concatenate all the encoded bytes list: some screen shots p/s: randomly tested Arabian, Chinese, Hindi, Japanese, Korean, Lao ,Punjabi, Russian, Tamil, Vietnamese etc.. still has some issues Edited April 18, 2018 by hanhphuc link added, 汉, date & syntax color Quote Link to comment Share on other sites More sharing options...
mit Posted May 30, 2018 Author Share Posted May 30, 2018 Hello Cloud you please help me? what's wrong to this code? (defun c:test () ;Step 1: read file (setq ret "Lee Mac & Marko Ribar\r\nHappy Birthday\r\nç¥ä½*们生日快ä¹\r\n幸ç¦\r\nChúc mừng sinh nháº*t\r\n" ) ;step 2: convert to char list (setq lst (vl-string->list ret)) ;Step 3: (U8:bytes lst ) function to filter the bytes list (setq lstt (U8:bytes lst)) ;Step 4: convert decimal to base 2, then apply the function UTF8->unicode to encode (foreach txt lstt (mapcar ''(( x ) (LM:dec->base x 2) ) 'txt)) (princ (UTF8->unicode 'txt )) ) ;Reference, post#138 ;https://stackoverflow.com/questions/643694/what-is-the-difference-between-utf-8-and-unicode (defun UTF8->unicode ( l / ls 8b d2 foo) ; encode UTF-8 to unicode ;;;hanhphuc 17.04.2018 (setq 8b '((s) (while (< (strlen s) (setq s (strcat "0" s))) s) d2 '((str) ;split string to two list (if (> (strlen str) 0) (cons (substr str 1 (d2 (setq str (substr str 9 )))) ) ) foo '(($ / pos i) ; base2 to decimal (setq i 0) (+ (cond ((while (and (> (strlen $) 0) (setq pos (vl-string-search "1" $))) (setq $ (substr $ (+ 2 pos)) i (+ i (expt 2 (strlen $))) ) ) ) (0) ) (atoi $) ) ) ls (mapcar ''((x / $) (setq $ (LM:dec->base (foo x) 16)) (if (= (strlen $) 1) (strcat "0" $) $ ) ) (d2 (apply 'strcat (mapcar ''((a x) (substr (8b a) (- 9 x) x)) l (cdr (assoc (length l) '((1 . (7)) (2 . (5 6)) (3 . (4 6 6)) (4 . (3 6 6 6))))) ) ) ) ) ) (apply 'strcat (vl-list* "\\U" (if (> (length ls) 1) "+" "+00") ls ) ) ) (defun U8:bytes (l / x ls) ;hanhphuc 17.04.2018 ;UTF-8 split the bytes (setq x (car l)) (if l (cons (vl-remove nil (cond ((<= 0 x 191) (setq ls (list x) l (cdr l) ) ls ) ((<= 192 x 223) (setq ls (list x (cadr l)) l (cddr l) ) ls ) ((<= 224 x 239) (setq ls (list x (cadr l) (caddr l)) l (cdddr l) ) ls ) ((<= 240 x 247) (setq ls (list x (cadr l) (caddr l) (cadddr l)) l (cddddr l) ) ls ) ) ) (U8:bytes l) ) ) ) (defun foo ( str ) ; read unicode - test version hanhphuc 17.04.2018 (apply 'strcat (mapcar ''( ( x ) (apply 'strcat (vl-list* (chr 92) "U+" (mapcar ''( (x / $) (setq $ ( LM:dec->base x 16)) (if (or (< x 10) (=(strlen $)1)) (strcat "0" $) $) ) (reverse x) ) ) ) ) ( '( ( f ) (f (vl-remove-if '(lambda (x) (vl-some '(lambda (y) (= x y) ) '( 254 255 )) ) (vl-string->list str) ) ) ) '( ( l ) (if l (cons (list (car l)(cadr l)) (f (cddr l))) ) ) ) ) ) ) ;; Decimal to Base - Lee Mac ;; Converts a decimal number to another base. ;; n - [int] decimal integer ;; b - [int] non-zero positive integer base ;; Returns: [str] Representation of decimal in specified base (defun LM:dec->base ( n b ) (if (< n b) (chr (+ n (if (< n 10) 48 55))) (strcat (LM:dec->base (/ n b) b) (LM:dec->base (rem n b) b)) ) ) Quote Link to comment Share on other sites More sharing options...
hanhphuc Posted May 30, 2018 Share Posted May 30, 2018 HelloCloud you please help me? what's wrong to this code? (defun c:test () ;Step 1: read file (setq ret "Lee Mac & Marko Ribar\r\nHappy Birthday\r\nç¥ä½*们生日快ä¹\r\n幸ç¦\r\nChúc mừng sinh nháº*t\r\n" ) ;step 2: convert to char list (setq lst (vl-string->list ret)) ;Step 3: (U8:bytes lst ) function to filter the bytes list (setq lstt (U8:bytes lst)) ;Step 4: convert decimal to base 2, then apply the function UTF8->unicode to encode (foreach txt lstt (mapcar ''(( x ) (LM:dec->base x 2) ) [color="red"]'txt[/color])) (princ (UTF8->unicode [color="red"]'txt[/color] )) ) good afford no worries learning from mistake, 'txt = (quote txt) QUOTE function returns without evaluating argument (setq txt "HELLO") ( princ [color="red"][b]'[/b][/color]txt ) TXT ( princ txt ) "HELLO" so change to this ;Step 4: convert decimal to base 2, then apply the function UTF8->unicode to encode (foreach [color="red"]txt[/color] lstt (princ ([color="blue"]UTF8->unicode[/color] (mapcar ''(( x ) (LM:dec->base x 2) ) [color="red"]txt[/color] )) ) ) (princ) be happy coding p/s: use read-char for reading unicode file Quote Link to comment Share on other sites More sharing options...
mit Posted May 30, 2018 Author Share Posted May 30, 2018 Thank you very mush hanhphuc Quote Link to comment Share on other sites More sharing options...
hanhphuc Posted May 31, 2018 Share Posted May 31, 2018 Thank you very mush hanhphuc you are welcome p/s: sorry it was typo #138 in reference link, it should be post#147 Quote Link to comment Share on other sites More sharing options...
