hi sir
please if you can help me
i have sheet with layout name start from
BWSIP-2R-DD-TP-M01 to BWSIP-2R-DD-TP-M10
now i take copy from this sheet but i want to rename layout name frome 01..10
to BWSIP-2R-DD-TP-M02 to BWSIP-2R-DD-TP-M20
In the time it takes to work out a lisp they could be renamed just click on the last one and use "Rename" option if you have more than 10 and this occurs all the time then please confirm.
thank sir for you replay
really yes always we have project some time more 70 layout in on sheet
and we copied for other design
Found a couple of minutes try this it has no error checking about layout names and numbers within.
(vl-load-com)
(defun renumlayout ( / doc tabs len tabsnewnum lenstr layname)
(setq doc (vla-get-activedocument (vlax-get-acad-object)))
(setq tabs  (vla-get-Layouts doc))
(setq len (vla-get-count tabs))
(alert (rtos len 2 0))
(setq newnum (getint "input last layout number"))
(if (> newnum len)
(vlax-for layname tabs
(setq tabname  (vla-get-name layname))
(if (= "Model" tabname)
(setq lenstr (strlen tabname))
(setq tabname (substr tabname 1 (- lenstr 2)))
(vla-put-name layname (strcat  tabname (rtos newnum 2 0)))
(setq newnum (- newnum 1))
(renumlayout)
Here's a quick example:
(defun c:foo (/ i l n o)
 ;; Prefix
 (setq pre "BWSIP-2R-DD-TP-M")
 ;; Start number
 (setq n 1)
 ;; Get all paperspace layouts
 (vlax-for x (setq lo (vla-get-layouts (vla-get-activedocument (vlax-get-acad-object))))
   (cond ((> (vla-get-taborder x) 0) (setq o (cons x o))))
 ;; Sort left to right
 (setq o (vl-sort o '(lambda (r j) (< (vla-get-taborder r) (vla-get-taborder j)))))
 ;; Apply a temp name to avoid duplicates
 (foreach l o (vla-put-name l (rtos (/ (getvar 'cdate) (vla-get-taborder l)) 2 12)))
 ;; Renumber
 (foreach l o
   (setq i (cond ((< n 10) (strcat "0" (itoa n)))
	  ((itoa n))
   (vla-put-name l (strcat pre i))
   (setq n (1+ n))
(vl-load-com)
Interesting - I typically use the Layout Handle ;)
That's because you're smarter than me :)
I am not sure I understand Lee's suggestion, but in theory a layout may have a name that matches the handle of another layout. So using layout handles as temporary names can be risky.
That applies to any methodology you choose...
Requesting for a LSP that can change layout tab from its original tab name into a new name(user defined). Hoping you can help me creating this script data.
Would like to create a batch layout rename.
TIA :)
