Hello everyone,
I'm facing a problem :oops:... I have a lot of blocks in the air that need to be connected two by two with a certain polyline.
I have a LISP code I've found on the net, I've modified the code, but the blocks do not fall vertically on polyline ... and I can not figure it out by doing the lisp code.
I attached the dwg file and the lisp code for example ... I remain deeply grateful for helping:D
Example code.dwgFetching info...
MY_snapToObj.lspFetching info...
The lisp code is finding the nearest point on the polyline, and not the vertical intersection with the polyline.
(defun c:snapToObj (/ c en posit pt pten ptobj pts_ss ss_len)
 (princ "\nSelecteaza PolyLinia Terenului: ")
 (setq en (ssget "_:S+."))
 (princ "\nSelecteaza Blocurile Gard: ")
 (setq pts_ss (ssget (list (cons 0 "INSERT"))))
(setq ss_len (sslength pts_ss))
(setq c 0)
 (while (< c ss_len)
   (setq pten (ssname pts_ss c))
   (setq ptobj (vlax-ename->vla-object pten))
	(setq pt(vlax-get ptobj 'InsertionPoint))
	(setq posit(make_inters ptobj (vlax-ename->vla-object (ssname en 0))))
   (vla-move ptobj (vlax-3d-point pt) (vlax-3d-point posit))
   (setq c (+ c 1))
(defun make_inters(insert curve / curve_vla insert_vla instpt inters_co var xl xl_vla)
(if(equal (type insert) "VLA-OBJECT")
	(setq insert_vla(vlax-ename->vla-object insert))
	(setq insert_vla insert)
(if(equal (type curve) "VLA-OBJECT")
	(setq curve_vla(vlax-ename->vla-object curve))
(setq instpt(vlax-get insert_vla 'InsertionPoint))
(entmake (list '(0 . "XLINE") '(100 . "AcDbEntity") '(100 . "AcDbXline") (cons 10 instpt) (cons 11 '(0 -1 0))))
(setq xl(entlast))
(setq var(vla-IntersectWith curve_vla (setq xl_vla(vlax-ename->vla-object xl)) acExtendNone))
(setq inters_co(vlax-safearray->list (vlax-variant-value var)))
(vla-Delete xl_vla)
inters_co
sorry for this code,you can replace it by yourself
	(if([color="red"]not[/color](equal (type insert) "VLA-OBJECT"))
(if([color="red"]not[/color](equal (type curve) "VLA-OBJECT"))
