miroslav_s Posted March 30, 2018 Posted March 30, 2018 (edited) Hello, I am trying to figure it out how to set what part of the garage to be visible in elevation view. When I use the elevation command I get the whole building in my elevation view as the result, see the link http://prntscr.com/iyq91l The thing is I only want to show the part of the garage that is above the ground in elevation view. See the link http://prntscr.com/iyqajh PARTLY SOLVED THE PROLEM: well I managed to find Youtube video tutorial on how it is done and I did manage to do it but not all the way. The tutorial shows how it is done but in my case I dont know how to remove concrete hatch and two lines that are still shown in the drawing. See here: http://prntscr.com/iyyotm http://prntscr.com/iyyr3q http://prntscr.com/iyys8x thanks in advace and best regards, Miro Edited March 31, 2018 by miroslav_s Quote
Bob658 Posted July 13, 2018 Posted July 13, 2018 I would have placed the objects below the GL on a separate level so they could be switched them off or when in paper space used a wipeout or when in paper space moved the bottom line of my viewport to up to GL when in paper space. Quote
