miroslav_s Posted March 29, 2018 Posted March 29, 2018 hello, where or more like HOW can I change the thickness of my slab so that on side is smaller then the other side. Like this: http://prntscr.com/iy69m0 thanks in advance, best regards, Miro Quote
welldriller Posted March 30, 2018 Posted March 30, 2018 1 way (yes it's time consuming) draw the bottom horizontal base line. Then draw the vertical lines on each end the height you want. Then draw the top horizontal line. Bingo big on one end smaller on the other. Quote
danellis Posted March 30, 2018 Posted March 30, 2018 You might be able to use a Body Modifier? dJE Quote
miroslav_s Posted March 30, 2018 Author Posted March 30, 2018 You might be able to use a Body Modifier? dJE Yepp you are right Thanks Miro Quote
miroslav_s Posted July 15, 2018 Author Posted July 15, 2018 1 way (yes it's time consuming) draw the bottom horizontal base line. Then draw the vertical lines on each end the height you want. Then draw the top horizontal line. Bingo big on one end smaller on the other. I was more thinking about slabs in Autocad Architecture....so thank you but NO that was not the answer I was hoping for. Your solution dont help at all. Thanks anyway Quote
