ktbjx Posted March 24, 2018 Posted March 24, 2018 you may think this is silly or a stupid question, but is there a way for me to type the command, and wherever the mouse is, it will simulate a left click... Quote
Grrr Posted March 24, 2018 Posted March 24, 2018 What exactly you are trying to do? Perhaps there would be a better approach. Quote
ktbjx Posted March 24, 2018 Author Posted March 24, 2018 What exactly you are trying to do? Perhaps there would be a better approach. im writing an AutoHotkey Script that uses the COM on Autocad and COM from Excel... basically, what the script does is get the XYZ coordinates of a line in Autocad, and find it in excel(it was DataExtract). since i cant figure out how will i click a line on Autocad, and since i still have the Autolisp code that Lee Mac made. i was thinking ill use that autolisp, instead of the VBA... thats why i was asking if i could select o click on a line when i type the command... BTW the proccess of the script is like this: i right click it will type the autolisp command i select a line and the script will press enter.... then from there, the script will find the line coordinates from Excel. if it finds the coordinate, I will type some values then begin from the start again. so you see, i was trying to lessen the time spent in pressing the right click and the pressing the left click again... is there a way so that i could just type the lisp command, and it will select a line where the cursor is??? BTW here is the autolisp: http://www.cadtutor.net/forum/showthread.php?97782-getting-X-Y-Z-Coordinates-of-a-line&p=667368&viewfull=1#post667368 what it does is copy to CLIPBOARD the selected line and from there i use that clipboard to find the coordinates in excel pretty much, i wanna tweak the autolisp code so it will select wherever the cursor at. Quote
Grrr Posted March 24, 2018 Posted March 24, 2018 You could use this modified version of Lee's code: (defun c:l2c ( / ent ) (if ; http://www.cadtutor.net/forum/showthread.php?97782-getting-X-Y-Z-Coordinates-of-a-line&p=667368&viewfull=1#post667368 (setq ent (cond ( ( (lambda ( / e r ) (and (setq e (car (nentselp (cadr (grread t))))) (member '(0 . "LINE") (entget e)) (setq r e) ) r ) ) ) ( ( (lambda (f / SS) (if (setq SS (cadr (ssgetfirst))) (f SS 0))) (lambda ( SS i / e ) (cond ( (not (setq e (ssname SS i))) nil) ( (member '(0 . "LINE") (entget e)) e ) ( (f SS (1+ i)) ) ) ) ) ) ( (LM:selectifobject "\nSelect line: " "LINE") ) ); cond ); setq ent (if (LM:copytoclipboard (LM:lst->str (mapcar 'rtos (append (cdr (assoc 10 (entget ent))) (cdr (assoc 11 (entget ent))) ) ) "\t" ) ) (princ "\nLine endpoints copied to clipboard.") ) ) (princ) ) Run the command, and the code will use the line that matches the first critera (list by priority): The cursor is over the LINE object, highlighting it (but it may be not selected) A selection was made (implied), the code will check for the first LINE object and use it User is prompted manually to select a LINE (with LM:selectifobject subfoo) BTW In my mind was the SendKeys approach, but apparently it doesn't work with mouse buttons, altho found some documentation , where my plan would be: (setq pxl (vk_Point2Pixel (cadr (grread t)))) (vlax-invoke ws 'SendKeys (strcat "{ClickLeft " (substr (apply 'strcat (mapcar '(lambda (x) (strcat ", " (vl-prin1-to-string x))) pxl)) 3) "}")) but the result is: Error: Exception occurred Quote
ktbjx Posted March 24, 2018 Author Posted March 24, 2018 You could use this modified version of Lee's code: (defun c:l2c ( / ent ) (if ; http://www.cadtutor.net/forum/showthread.php?97782-getting-X-Y-Z-Coordinates-of-a-line&p=667368&viewfull=1#post667368 (setq ent (cond ( ( (lambda ( / e r ) (and (setq e (car (nentselp (cadr (grread t))))) (member '(0 . "LINE") (entget e)) (setq r e) ) r ) ) ) ( ( (lambda (f / SS) (if (setq SS (cadr (ssgetfirst))) (f SS 0))) (lambda ( SS i / e ) (cond ( (not (setq e (ssname SS i))) nil) ( (member '(0 . "LINE") (entget e)) e ) ( (f SS (1+ i)) ) ) ) ) ) ( (LM:selectifobject "\nSelect line: " "LINE") ) ); cond ); setq ent (if (LM:copytoclipboard (LM:lst->str (mapcar 'rtos (append (cdr (assoc 10 (entget ent))) (cdr (assoc 11 (entget ent))) ) ) "\t" ) ) (princ "\nLine endpoints copied to clipboard.") ) ) (princ) ) Run the command, and the code will use the line that matches the first critera (list by priority): The cursor is over the LINE object, highlighting it (but it may be not selected) A selection was made (implied), the code will check for the first LINE object and use it User is prompted manually to select a LINE (with LM:selectifobject subfoo) BTW In my mind was the SendKeys approach, but apparently it doesn't work with mouse buttons, altho found some documentation , where my plan would be: (setq pxl (vk_Point2Pixel (cadr (grread t)))) (vlax-invoke ws 'SendKeys (strcat "{ClickLeft " (substr (apply 'strcat (mapcar '(lambda (x) (strcat ", " (vl-prin1-to-string x))) pxl)) 3) "}")) but the result is: Error: Exception occurred OMG! This is the one!!!! exactly what i have in mind! you sir are a genius! now i don't have to left click! ill just hover the mouse to the line! Quote
Grrr Posted March 24, 2018 Posted March 24, 2018 OMG! This is the one!!!! exactly what i have in mind!you sir are a genius! now i don't have to left click! ill just hover the mouse to the line! You are wellcome! BTW if you don't want to be forced to hover directly over the line, and have the option to use the closest one to the cursor - Replace the: (setq ent ...) With: (setq ent (cond ( ( (lambda ( / e r ) (and (setq e (car (nentselp (cadr (grread t))))) (member '(0 . "LINE") (entget e)) (setq r e) ) r ) ) ) ( ( (lambda (f / SS) (if (setq SS (cadr (ssgetfirst))) (f SS 0))) (lambda ( SS i / e ) (cond ( (not (setq e (ssname SS i))) nil) ( (member '(0 . "LINE") (entget e)) e ) ( (f SS (1+ i)) ) ) ) ) ) ( ( (lambda ( / SS p i tmp r ) (and (setq SS (ssget "_X" (list '(0 . "LINE") (if (= 1 (getvar 'cvport)) (cons 410 (getvar 'ctab)) '(410 . "Model"))))) (setq p (cadr (grread t))) (repeat (setq i (sslength SS)) (setq tmp (mapcar 'cdr (vl-remove-if-not (function (lambda (x) (member (car x) '(-1 10 11)))) (entget (ssname SS (setq i (1- i))))))) (setq tmp (cons (car tmp) (apply (function min) (mapcar (function (lambda (x) (distance p x))) (cdr tmp))))) (cond ( (not r) (setq r tmp) ) ( (apply '> (mapcar 'cdr (list r tmp))) (setq r tmp) ) ) ) ) (car r) ) ) ) ( (LM:selectifobject "\nSelect line: " "LINE") ) ); cond ); setq ent Still a question remains if its possible to send a mouse click with the SendKeys method. Quote
marko_ribar Posted March 24, 2018 Posted March 24, 2018 Perhaps... : It seems that you forgot ab this one Grrr... http://www.cadtutor.net/forum/showthread.php?96083-Brush-Select-Circle-Select/page2&p=#11 Quote
Grrr Posted March 24, 2018 Posted March 24, 2018 Perhaps... : It seems that you forgot ab this one Grrr... http://www.cadtutor.net/forum/showthread.php?96083-Brush-Select-Circle-Select/page2&p=#11 I remember it, just didn't found a connection. Still your code (expanding circle approach) requires rewriting to match OP's request here - remove grread inputs and use optimal increment value for the fuzz, to reduce the requested input just to the lisp-call. Quote
benhubel Posted March 26, 2018 Posted March 26, 2018 You could use this modified version of Lee's code: (defun c:l2c ( / ent ) (if ; http://www.cadtutor.net/forum/showthread.php?97782-getting-X-Y-Z-Coordinates-of-a-line&p=667368&viewfull=1#post667368 (setq ent (cond ( ( (lambda ( / e r ) (and (setq e (car (nentselp (cadr (grread t))))) (member '(0 . "LINE") (entget e)) (setq r e) ) r ) ) ) ( ( (lambda (f / SS) (if (setq SS (cadr (ssgetfirst))) (f SS 0))) (lambda ( SS i / e ) (cond ( (not (setq e (ssname SS i))) nil) ( (member '(0 . "LINE") (entget e)) e ) ( (f SS (1+ i)) ) ) ) ) ) ( (LM:selectifobject "\nSelect line: " "LINE") ) ); cond ); setq ent (if (LM:copytoclipboard (LM:lst->str (mapcar 'rtos (append (cdr (assoc 10 (entget ent))) (cdr (assoc 11 (entget ent))) ) ) "\t" ) ) (princ "\nLine endpoints copied to clipboard.") ) ) (princ) ) It appears as if this code is missing the Select If Object function, although I might just be reading it wrong. ;; Select if Object - Lee Mac ;; Continuously prompts the user for a selection of a specific object type (defun LM:selectifobject ( msg typ / ent ) (while (progn (setvar 'errno 0) (setq ent (car (entsel msg))) (cond ( (= 7 (getvar 'errno)) (princ "\nMissed, try again.") ) ( (null ent) nil) ( (not (wcmatch (cdr (assoc 0 (entget ent))) typ)) (princ "\nInvalid object selected.") ) ) ) ) ent ) Perhaps... : It seems that you forgot ab this one Grrr... http://www.cadtutor.net/forum/showthread.php?96083-Brush-Select-Circle-Select/page2&p=#11 I still make use of this program almost daily. The version I use now is a heavily modified one that filters based on layers, but either way, it's been quite useful. Thanks again for it. Quote
Grrr Posted March 26, 2018 Posted March 26, 2018 It appears as if this code is missing the Select If Object function, although I might just be reading it wrong. Yea I only modified the original main, and didn't included the 3 subfunctions that it uses, since OP already mentioned the source code: BTW here is the autolisp: http://www.cadtutor.net/forum/showthread.php?97782-getting-X-Y-Z-Coordinates-of-a-line&p=667368&viewfull=1#post667368 Quote
aridzv Posted February 26, 2024 Posted February 26, 2024 Hi. I need to do what is in the title: to select the object where the mouse curssor is. I wrote a short code that go from paper space to model space and use part of the code from the examples here to select an object where the curssor is but I get some other list. here is the code I wrote: (defun c:test3 ( / pt pt1) (setq pt (getpoint)) ;;get point in paper space ;(setq pt1 (trans pt 3 0)) (command "._MSPACE") (setq e (car (nentselp (cadr (grread t))))) (command "._PSPACE") (princ e) (entget e) ) in the attached drawing I'm in Layout1 tab. run the code, click on the elbow block, but the return enthity is not the block... I need to return to paper space with the block entity name... thanks, aridzv. Drawing1.dwg Quote
Steven P Posted February 26, 2024 Posted February 26, 2024 Try this: (defun c:test3 ( / pt pt1) (setq pt (getpoint)) ;;get point in paper space ; (setq pt1 (trans pt 3 0)) (command "._MSPACE") (setq e (car (last (nentselp (cadr (grread t)))))) (command "._PSPACE") (princ e) (entget e) ) nentselp, like nentsel, returns a list, the first item, (car ) is the nested entity that was selected - so if you select a block it will be maybe the line within the block, info on the next two are online, the last item in the list is the parent entity - in your case the complete block "Welding Elbow"... so add a (last ) into the code to get that 1 Quote
aridzv Posted February 26, 2024 Posted February 26, 2024 @Steven P works like a charm -Thanks!!! Quote
