i am new on Autocad VBA, i found this code somewhere..
thsa what i need but i want to change the
SelectOnScreen part..
Here's the code:
Public Sub LineDetail()
Dim oSS As AcadSelectionSet
Dim oEntity As AcadEntity
Dim iFilterCode(0) As Integer
Dim vFilterValue(0) As Variant
 On Error Resume Next
 Application.ActiveDocument.SelectionSets("Lines").Delete
 On Error GoTo 0
 Set oSS = Application.ActiveDocument.SelectionSets.Add("Lines")
 iFilterCode(0) = 0: vFilterValue(0) = "Line"
 oSS.SelectOnScreen iFilterCode, vFilterValue
 If oSS.Count Then
   For Each oEntity In oSS
     Dim oLine As AcadLine
     Set oLine = oEntity
     With oLine
       MsgBox "StartPoint: " & .StartPoint(0) & ", " & .StartPoint(1) & ", " & .StartPoint(2) & vbCrLf & _
              "EndPoint  : " & .EndPoint(0) & ", " & .EndPoint(1) & ", " & .EndPoint(2)
     End With
   Next oEntity
 End If
End Sub
i think its this code that i need to change?
but IDK how, is there a way for me to atleast select the previous line i selected???
plus, the code loops when i select multiple lines..
i only want to select 1 LINE at a time...
