miroslav_s Posted March 23, 2018 Posted March 23, 2018 (edited) Hello, can someone please tutor me how to solve the problem that I am having. I have a door placed on one wall http://prntscr.com/ivaeo0 but the same door is not showing on the next wall above http://prntscr.com/ivav2l Is the solution to make hole with "opening" command? But if I do that and later when I decide to perhaps move the door then the hole will not follow and I have to move the hole every time I move the door, right? When using the Opening command http://prntscr.com/ivb7pf Also need to tell you, perhaps this is important info: the wall above is 10 mm thinner then the wall under http://prntscr.com/ivayx7 Thanks in advance for info and help. Best regards, Miro Edited March 23, 2018 by miroslav_s Quote
danellis Posted March 23, 2018 Posted March 23, 2018 Do you *need* it to be two separate walls? I'd be inclined to do it as a single wall and create a new style to incorporate the different thickness/materials/construction. Otherwise, yes, you'll have to use an opening in the second wall and adjust that manually whenever two door or either of the two walls changes. dJE Quote
miroslav_s Posted March 23, 2018 Author Posted March 23, 2018 (edited) Do you *need* it to be two separate walls? I'd be inclined to do it as a single wall and create a new style to incorporate the different thickness/materials/construction. Otherwise, yes, you'll have to use an opening in the second wall and adjust that manually whenever two door or either of the two walls changes. dJE Hi danellis, yes you are so right. Just learned how to change components in a wall in horizontal direction (never done that before ) and now it is just the way I wanted. http://prntscr.com/ivhhyd and http://prntscr.com/ivhkip Thank you. Best regards to you. Miro Edited March 23, 2018 by miroslav_s Quote
danellis Posted March 24, 2018 Posted March 24, 2018 No problem, happy to be able to help. Well done, Miro dJE Quote
