All,
Can someone help me with getting rid of the "ERROR" that happens when i hit enter or return to end the routine. Basically this give me the chance to reset my titleblocks so they print in order.
(defun c:TRESET()
(vl-load-com)
(while
  (and(vl-cmdf "_.copybase" pause (ssget "_:S") "")
  (vl-cmdf "_.pasteclip"(getvar "LASTPOINT"))
  (vl-cmdf "_.erase" "_p" ""))
); end of c:TRESET
Thanks,
Brian
not tested but maybe as simple as :
 (while (setq ss (ssget "_:S")) (command "_.draworder" ss "" "_front"))
And here's something without command calls:
(defun c:treset	(/ _entsel e o)
 (defun _entsel (msg / p r)
   (setvar "ErrNo" 0)
   (while (not	(cond ((and (null (setq p (entsel (strcat "\n" msg)))) (/= 52 (getvar 'errno)))
	       (prompt "\nOops! Selection missed. Try again...")
	      ((null p) t)
	      ((setq r p))
   r
 (while (setq e (car (_entsel "Select an object: ")))
   (cond ((vlax-write-enabled-p (setq o (vlax-ename->vla-object e)))
   (vla-copy o)
   (print (strcat (cdr (assoc 0 (entget e))) " copied..."))
   (entdel e)
(vl-load-com)
Edited by ronjonp
Ronjonp, Rlx,
Thanks for your help guys. Works great ronjonp thanks for the rewrite its a lot smoother.
Thanks,
Brian
ronjonp,
I have a question after running it I found out that if you miss the title block it ends the command is there a way to incorporate and error to say you missed and to try again like the following,
(while
     (progn (setvar 'ERRNO 0)
            (setq ent (meth (cond (msg)
                                  ("\nSelect object: ")
            (cond ((eq (getvar 'ERRNO) 7) (princ "\nMissed, try again."))
                  ((eq (type (car ent)) 'ENAME)
                   (if (and fnc (not (fnc ent)))
                     (princ "\nInvalid object!")
   ent
Thanks,
Brian
ronjonp,
Thank you so much for your help :D:D BTW where in Colorado are you located? i used to live in Colorado Springs. i loved it out there...
Thanks,
Brian
Glad to help :) .. I'm in the Fort Collins area.
