Transfer ObjectId[] idArray between methods in class
How can idArray passed made to be used in another method or event in the same class after the above
code is ran?
placing "public static ObjectId[] idArray;" in the form general area does not work
Code is given below:
[CommandMethod("PICKFIRST1")]
public void Pickfirst1()
Editor ed = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor;
Database db = HostApplicationServices.WorkingDatabase;
Transaction tr = db.TransactionManager.StartTransaction();
try
TypedValue[] filList = new TypedValue[1] {new TypedValue((int)DxfCode.Start, "INSERT")
SelectionFilter filter = new SelectionFilter(filList);
PromptSelectionOptions opts = new PromptSelectionOptions();
opts.MessageForAdding = "Select block references: ";
PromptSelectionResult res = ed.GetSelection(opts, filter);
SelectionSet selSet = res.Value;
// How can idArayy be made shared in another method?
ObjectId[] public static ObjectId[] idArray; = selSet.GetObjectIds();
tr.Commit();
catch (Autodesk.AutoCAD.Runtime.Exception ex)
ed.WriteMessage(("Exception: " + ex.Message));
finally
tr.Dispose();
Thank you,
