Hello,
Just very basic questions, thank you for all your feedback and input in advance. i came across toturial about 3 views othograpic projection, my questions are:
1. Is the space or distance A and B must be equaled in order to get the accurate when project the line to create the next view?
2. I assume the projection angle must always be 45 degree correct?
Edited by Sengna
clarify
C should equal C and yes, the line should be at 45°
[ATTACH=CONFIG]63515[/ATTACH]
If C must be equal distance then A must be the same distance with B too right? Thank you Irm.
Well you could always run your own test by making A not equal to B then see what the results are.
That's the purpose of the 45 deg line, simple plane geometry.
