itacad Posted March 9, 2018 Posted March 9, 2018 Hello, in my work (unfortunately) I spend a lot (too much) of time copying texts between blocks...Fortunately, however, I found some lisps that speed up this operation! But I could not find alternatives that I would need in two particular situations: Situation 1 (very important for me): cumulative copy in one destination. For example A,B,C, D1, 23, Z = ABCD123Z in the destination Situation 2 (not very important but reccurent); single paste and return to copy. The lisp I use allows, once copied the text, to paste it many times, but usually I have to paste it once, and once done it would be much more practical have already ready the copy phase... have you ever seen something similar? Thank you in advance Quote
itacad Posted March 12, 2018 Author Posted March 12, 2018 Hi, I add to the topic a further feature that I could not find: starting from the fact that in the windows clipboard I put text I want to transcribe in autocad (in a single line text, multiline text or attribute), have you ever create a lisp to paste directly from the clipboard to the autocad's text object by click over? Greetings Quote
itacad Posted March 13, 2018 Author Posted March 13, 2018 he he...think that I use a gaming mouse and "ctrl+a" and "ctrl+v" are stored on special buttons so the operation is already very fast (I do not even have to take my hands off the mouse)...but not comparable with the speed obtained with a specific lisp... I would not look like a lazy man, but I am very happy when I can shorten a single operation that I do repeatedly! Hi! Quote
rlx Posted March 14, 2018 Posted March 14, 2018 ok , just some lunch copy & paste : (defun c:tst ( / p1 p2 ents) (while (and (setq p1 (getpoint "\n1st corner : ")) (setq p2 (getcorner p1 "\n2nd corner : ")) (setq ents (sfs p1 p2))(setq ents (el_sort ents p1 p2))) (alert (apply 'strcat (vl-remove-if 'void (mapcar '(lambda (x / s)(cdr (assoc 1 (entget x)))) ents))))) (princ) ) (defun inside_amy (ent p1 p2 / ip ) (if (and (>= (car (setq ip (getip ent))) (min (car p1)(car p2))) (<= (car ip) (max (car p1)(car p2))) (>= (cadr ip) (min (cadr p1)(cadr p2))) (<= (cadr ip) (max (cadr p1)(cadr p2)))) t nil)) ; get insertionpoint (defun getip (e) (list (cadr (assoc 10 (entget e)))(caddr (assoc 10 (entget e))))) ; black hole with hawking radiation (defun void (x) (if (member x (list "" " " " " " " " " " " nil '())) t nil)) ; scan for string (defun sfs ( %p1 %p2 / i ss el e et) (if (setq i 0 ss (ssget "c" %p1 %p2)) (while (setq e (ssname ss i)) (setq et (cdr (assoc 0 (entget e))) i (1+ i)) (cond ((member et '("TEXT" "MTEXT" "ATTRIB" "ATTDEF"))(setq el (cons e el))) ((= et "INSERT") (mapcar '(lambda (x) (if (inside_amy x %p1 %p2)(setq el (cons x el))))(get-bents e)))))) el) ; get block entities (defun get-bents ( b / obj e lst) ;attrib (setq obj (vlax-ename->vla-object b)) (if (eq :vlax-true (vla-get-HasAttributes obj)) (setq lst (mapcar 'vlax-vla-object->ename (vlax-invoke obj 'GetAttributes)))) ;text , disable if only attributes are needed (setq e (tblobjname "block" (vla-Get-EffectiveName obj))) (while (setq e (entnext e)) (if (member (cdr (assoc 0 (entget e))) (list "TEXT" "ATTDEF")) (setq lst (cons e lst)))) lst) ; mode = nil : sort list with entities from y-max to y-min , mode = t : sort from y-min to y-max (defun sort_ents_y ( %ents mode) (vl-sort %ents '(lambda (e1 e2) ((if mode > <) (caddr (assoc 10 (entget e1))) (caddr (assoc 10 (entget e2))))))) ; mode = nil : sort list with entities from x-max to x-min , mode = t : sort from x-min to x-max (defun sort_ents_x ( %ents mode) (vl-sort %ents '(lambda (e1 e2) ((if mode > <) (cadr (assoc 10 (entget e1))) (cadr (assoc 10 (entget e2))))))) (defun el_sort ( %el %p1 %p2 / dX dY) (setq dX (- (car %p2) (car %p1)) dY (- (cadr %p2) (cadr %p1))) (if (> (abs dX) (abs dY))(if (> dX 0)(sort_ents_x %el nil)(sort_ents_x %el t)) (if (> dY 0)(sort_ents_y %el nil)(sort_ents_y %el t))) ) ps direction of selection matters... gr. Rlx Quote
itacad Posted March 15, 2018 Author Posted March 15, 2018 Thank you rlx, try your lisp but I don't understand how it works... In the meantime I found this topic in your huge forum http://www.cadtutor.net/forum/showthread.php?87782-Are-there-a-way-copy-and-paste-via-clipboard-by-lisp "Demopaste" does exactly what I need, but it works only with single line text...what a pity Quote
rlx Posted March 15, 2018 Posted March 15, 2018 (edited) Thank you rlx, try your lisp but I don't understand how it works...In the meantime I found this topic in your huge forum http://www.cadtutor.net/forum/showthread.php?87782-Are-there-a-way-copy-and-paste-via-clipboard-by-lisp "Demopaste" does exactly what I need, but it works only with single line text...what a pity Routine was just a demo to combine some texts. In place for the alert function you would place an entsel to select entity to place the combined strings in. Most of the functions you seek can be done with my VT routine , like row(s) to row(s) etc. Gr. Rlx Edited March 16, 2018 by rlx Quote
BIGAL Posted March 16, 2018 Posted March 16, 2018 Sounds like a 1 size fits all, using a ssget you could pick 1 or multiple objects, repeating as required. For the 1 at a time just look at it is it text or mtext and make new string, for a multiple again look at it but take into account say Y co-ord and sort before adding together. Very much like the RLX code a number of defuns needed the multi would be done by the fact that the ssget has only 1 item so its a single go to next pick object. Not a 5 minute job. Quote
BIGAL Posted March 16, 2018 Posted March 16, 2018 If you pay peanuts then you get monkeys coding. (defun c:addtxt ( / obj ans) (while (setq obj (vlax-ename->vla-object (car (entsel "\nPick text object")))) (setq ans (strcat ans (vla-get-textstring obj))) ) (princ ans) ) 1 Quote
rlx Posted March 16, 2018 Posted March 16, 2018 If you pay peanuts then you get monkeys coding. hahaha The way I see it , and this has been described in many different ways, if you want to help somebody with their homework , you don't help them by doing their homework for them. gr. Rlx Quote
rlx Posted March 16, 2018 Posted March 16, 2018 (edited) ok then, because its weekend some more lunch fun : routine allows user to continuously copy string from one object to another. Program uses grread so during execution no transparent commands can be used. To make up for this , you can use Z key for zoom , E key for zoom extents , + and - key for zooming in or out. Space , enter of Esc cancels the loop. ; rlx 19-3-2018 : text-copy-in-a-loopy , copy text string from one object to another (defun c:t2 ( / e1 e2 osm) (setq osm (getvar "snapmode"))(setvar "snapmode" 0) (princ "\nEsc, enter, Rmouse to cancel, zoom with E(extend), Z(oom) or + / -\nSelect object with string :") (while (setq e1 (RlxSel "\nSource text : ")) (if (setq e2 (RlxSel "\nTarget text : "))(progn (update_txt e1 e2 )(redraw e1 4)(redraw e2 4)))) (setvar "snapmode" osm) (princ) ) (defun update_txt (%source %target) (if (vlax-property-available-p (vlax-ename->vla-object %target) 'textstring t) (vla-put-textstring (vlax-ename->vla-object %target) (vla-get-textstring (vlax-ename->vla-object %source))))) (defun has_string (e) (vlax-property-available-p (vlax-ename->vla-object e) 'textstring)) (defun RlxSel ( $msg / done-selecting inp i p2 result e ent) (princ $msg) (setq done-selecting nil) (while (not done-selecting) (setq inp (vl-catch-all-apply 'grread (list nil 4 2))) (if (vl-catch-all-error-p inp) (setq done-selecting t result nil) (cond ; if point selected ((= (car inp) 3) ; if point has object under it (if (setq ent (nentselp (cadr inp))) (setq e (car ent))) (cond ; if we have object and object is the right type we have a winner ((and e (has_string e)) (redraw e 3)(setq done-selecting t result e)) ; maybe its the parent - this happens when type is dimension and you select dimensions text ((and (caddr ent) (setq ent (last (last ent)))(has_string ent)) (redraw ent 3)(setq done-selecting t result ent)) ; sorry object is not the right stuf ((and e (not (has_string e))) (princ "\rThis entity contains no text string")) ; missed , no object found under selected point ... try crossing selection (t (if (and (setq i 0 p2 (getcorner (cadr inp) "\rOther corner : ")) (setq ss (ssget "c" (cadr inp) p2))) (while (and (not done-selecting) (setq e (ssname ss i))) (if (has_string e)(progn (redraw e 3) (setq result e done-selecting t))) (setq i (1+ i)))) );end t ); end cond ); end (= (car inp) 3) ; user pressed E of e ((member inp '((2 69)(2 101))) (command "zoom" "e")) ; user clicked R-mouse button, pressed enter or space (done selecting) ((or (equal (car inp) 25)(member inp '((2 13)(2 32)))) (setq done-selecting t result nil)) ; user pressed + ((equal inp '(2 43)) (command "zoom" "2x")) ; user pressed - ((equal inp '(2 45)) (command "zoom" ".5x")) ; user pressed z or Z ((member inp '((2 122)(2 90))) (command "'zoom" "")) ) ) ) result ) gr.Rlx Edited March 19, 2018 by rlx Quote
BIGAL Posted March 17, 2018 Posted March 17, 2018 rlx the reason I thought use ssget as you can pick 1 or pick multiple by not putting any filter about selecting, just have the filter *text,dimension, then if you had random rows of *text you could accept join in say there y value order. I just picked a column of individual text {window} + 1 mtext {pick} so would be in draw order by doing as single picks {window} sort on Y + single pick + {window} sort on Y and so on (setq ss (ssget (list (cons 0 "*text")))) Quote
rlx Posted March 17, 2018 Posted March 17, 2018 rlx the reason I thought use ssget as you can pick 1 or pick multiple by not putting any filter about selecting, just have the filter *text,dimension, then if you had random rows of *text you could accept join in say there y value order. I just picked a column of individual text {window} + 1 mtext {pick} so would be in draw order by doing as single picks {window} sort on Y + single pick + {window} sort on Y and so on (setq ss (ssget (list (cons 0 "*text")))) Just cut copy paste (and lunched) something together. Not claiming it's better. Just wanted routine that allows single pick , autoswitch to window (crossing actually) if needed , and can also find strings in nested entities etc. It workes just fine for me in a couple of routines I use daily but if you have something better , please do post because what I like most about your codes is your no-nonsense approach and I often think , how did I not see that... I usually try to make code that I can use in more applications, even if it means some parts can be shorter. But that's an old discussion , what's better , faster code of less development time by beeing able to quickly paste something together... I'm clearly fan of the latter. When programs are getting bigger , your have to pay more attention to a good structure , at least , thats my personal experience. gr. Rlx Quote
BIGAL Posted March 17, 2018 Posted March 17, 2018 Give the task to 4 people and you will get 4 different answers to the final solution. I think its time to wait for itacad before any more changes. Quote
itacad Posted March 22, 2018 Author Posted March 22, 2018 here I am! sorry for the delay of the reply! I try the rlx's lisp and it works how I need! Thank you very much! Quote
rlx Posted March 22, 2018 Posted March 22, 2018 here I am! sorry for the delay of the reply!I try the rlx's lisp and it works how I need! Thank you very much! nos problemos , you're welcome gr.Rlx Quote
itacad Posted March 30, 2018 Author Posted March 30, 2018 Hello! another topic found in the forum that fix the problem! http://www.cadtutor.net/forum/showthread.php?18016-Lisp-for-Coping-a-text-to-another-like-match-properties Quote
rlx Posted March 30, 2018 Posted March 30, 2018 Hello! another topic found in the forum that fix the problem!http://www.cadtutor.net/forum/showthread.php?18016-Lisp-for-Coping-a-text-to-another-like-match-properties doesn't appear to be entirely stable but nevertheless it has some interesting lines of code so thanx for the link gr. Rlx Quote
Johnc Posted January 14, 2019 Posted January 14, 2019 Thank you ; rlx, really like the t2 code and use this routine all the time. Please could I ask for some help with the following : I would like to modify to supply my block names and tags for the copy. As I would like to get a master block mapped to Vault. From Blockname = "REVB", attribute, tag = "ISSUE" To Blockname = "MREVB" attribute, tag = "MISSUE" I have been modifying Coppy_att from Lee Mac and this works well for some of my attributes but I need to copy multiline attribute text and this routine only takes the first line. The other problem I have is that I have multiple instances of REV and want to only use the last inserted instance. Any help gratefully received J Quote
rlx Posted January 14, 2019 Posted January 14, 2019 (edited) Not sure what you want so a before & after dwg would be helpful. But if you want to cross link attribute values I have writen a program a while back, RlxBlk that has this option but it might be a relatively difficult program to use. Not tested for multi-line attributes though cause I never use them but there's a first time for everyting else if you have one master block , is a simple matter of reading its values and copy it to all the blocks with name you specify. Doesn't Lee have on his site a copy function that copies formatting too? Would have to do a quick test to see if ssget selects a specific block in order of insertion else I'm not sure it is possible to see what was the last block. Entlast is usually used right after a block is inserted. Edited January 14, 2019 by rlx Quote
