rmsmit02 Posted February 28, 2018 Posted February 28, 2018 Hello All, I am working on making Bills of Materials with Block information. I use tubing as a main component in my data extractions. What I would like to do is be able to extract the text overwritten length that I dictate from the all dimension leaders with the same part number, and add them to get an overall length of tubing used in the assembly. For instance if I have two blocks, both with the part number "tube 1" but one has a dimension leader where I overwrite 5 (inches) and one has a dimension leader where I overwrite 6 I would like the data extraction to show "tube 1" with 11 (inches). Much appreciated! Quote
BIGAL Posted March 1, 2018 Posted March 1, 2018 Sounds simple for the best help post a dwg with a couple of blocks. 1 Quote
rmsmit02 Posted March 2, 2018 Author Posted March 2, 2018 Hello, I would like the QTY of SIL-C-0250-2 to read 19.0 and the QTY of SIL-C-0625-4 to read 12.0 even though the measured distances aren't equal to the overwritten distances. Quote
rmsmit02 Posted March 5, 2018 Author Posted March 5, 2018 My mistake, I have added the image now. Thanks! Quote
