Delete all points/nodes in drawing (also in blocks)
DesmetMartin
Hi,
I'm searching for a lips or command/method to delete ALL points from a drawing (.dwg).
This is needed because our company gets a lot of drawings from other companys where in there drawing are a lot of points/nodes.
We need this to be deleted in a few cllicks instead of opening the blocks and delete them.
We currently have Acad 2016 and will switch to 2018 in a few months.
Thank you in advance!
Kind regards,
Martin
(defun c:blitzH (/ adoc)
 (vlax-for blk (vla-get-blocks
		   (setq adoc	(vla-get-ActiveDocument (vlax-get-acad-object))
  [color="blue"] (if [/color](eq :vlax-false (vla-get-isXref blk))
    (vlax-for h blk
	 (if
	   (and (vlax-write-enabled-p h)
		   (eq (vla-get-ObjectName h) "AcDbPoint")
	    (vla-delete h)
[b][color="blue"] )[/color][/b]
 (vla-regen aDoc acAllViewports)
But of course, there are other factors to consider like locked layer and some
Edited by pBe
Or if you just don't want to see them: (setvar 'pdmode 1)
Yes, that too. :D
Hi pBe.
You may have omitted one of these functions. IF, OR, AND before checking if the block definition is not an External Reference. ;)
Hi pBe.
:shock: You are right. Good catch Tharwat.
My $0.05 in my autoload
(defun c:PTY ()
(setvar 'pdmode 35) ; turn on ptype
(setvar 'pdsize 0.2)
(defun c:PTYY () ; turn off ptype
(setvar 'pdmode 1)
