Sample.dwgUnavailable
Hi all,
I want to write a program which will export the coordinates of vertices for selected polylines with Object Data which corresponds to each polyline. Please refer to a sample drawing attached with this thread.
I am happy with this program to export coordinates
;             (Export LWPOLYLINE Vertices & Points to File)
;            Copyright (C) 2000 DotSoft, All Rights Reserved
;                   Website: http://www.dotsoft.com
; DISCLAIMER:  DotSoft Disclaims any and all liability for any damages
; arising out of the use or operation, or inability to use the software.
; FURTHERMORE, User agrees to hold DotSoft harmless from such claims.
; DotSoft makes no warranty, either expressed or implied, as to the
; fitness of this product for a particular purpose.  All materials are
; to be considered ‘as-is’, and use of this software should be
; considered as AT YOUR OWN RISK.
;;Revised 8/23/07 CAB to report coordinates in current UCS
(defun c:ptexport ()
 (setq sset (ssget '((-4 . "<OR")(0 . "POINT")
                     (0 . "LWPOLYLINE")(-4 . "OR>"))))
 (if sset
     (setq itm 0 num (sslength sset))
     (setq fn (getfiled "Point Export File" "" "txt" 1))
     (if (/= fn nil)
         (setq fh (open fn "w"))
         (while (< itm num)
           (setq hnd (ssname sset itm))
           (setq ent (entget hnd))
           (setq obj (cdr (assoc 0 ent)))
           (cond
             ((= obj "POINT")
               (setq pnt (cdr (assoc 10 ent)))
               (setq pnt (trans pnt 0 1));;**CAB
               (princ (strcat (rtos (car pnt) 2  ","
                              (rtos (cadr pnt) 2  ","
                              (rtos (caddr pnt) 2 ) fh)
               (princ "\n" fh)
             ((= obj "LWPOLYLINE")
               (if (= (cdr (assoc 38 ent)) nil)
                 (setq elv 0.0)
                 (setq elv (cdr (assoc 38 ent)))
               (foreach rec ent
                 (if (= (car rec) 10)
                     (setq pnt (cdr rec))
                                    (rtos elv 2 ) fh)
                     (princ "\n" fh)
             (t nil)
           (setq itm (1+ itm))
         (close fh)
(princ "\nPoint Export loaded, type PTEXPORT to run.")
Now I want to add Object data such as:
1. For polylines on 'LVCable' layer - CSAMetric, Conductor, FeederNo, NoOfCores
2. For polylines on other layers - CSABlue, CSANeutral, CSARed, CSAYellow, FeederNo
Thank you
Best wishes,
Jes G
If you really want to write this program, most of the legwork is already HERE.
