jes_g Posted February 20, 2018 Posted February 20, 2018 Sample.dwgFetching info... Hi all, I want to write a program which will export the coordinates of vertices for selected polylines with Object Data which corresponds to each polyline. Please refer to a sample drawing attached with this thread. I am happy with this program to export coordinates ; ---------------------------------------------------------------------- ; (Export LWPOLYLINE Vertices & Points to File) ; Copyright (C) 2000 DotSoft, All Rights Reserved ; Website: http://www.dotsoft.com ; ---------------------------------------------------------------------- ; DISCLAIMER: DotSoft Disclaims any and all liability for any damages ; arising out of the use or operation, or inability to use the software. ; FURTHERMORE, User agrees to hold DotSoft harmless from such claims. ; DotSoft makes no warranty, either expressed or implied, as to the ; fitness of this product for a particular purpose. All materials are ; to be considered ‘as-is’, and use of this software should be ; considered as AT YOUR OWN RISK. ; ---------------------------------------------------------------------- ;;Revised 8/23/07 CAB to report coordinates in current UCS (defun c:ptexport () (setq sset (ssget '((-4 . "<OR")(0 . "POINT") (0 . "LWPOLYLINE")(-4 . "OR>")))) (if sset (progn (setq itm 0 num (sslength sset)) (setq fn (getfiled "Point Export File" "" "txt" 1)) (if (/= fn nil) (progn (setq fh (open fn "w")) (while (< itm num) (setq hnd (ssname sset itm)) (setq ent (entget hnd)) (setq obj (cdr (assoc 0 ent))) (cond ((= obj "POINT") (setq pnt (cdr (assoc 10 ent))) (setq pnt (trans pnt 0 1));;**CAB (princ (strcat (rtos (car pnt) 2 "," (rtos (cadr pnt) 2 "," (rtos (caddr pnt) 2 ) fh) (princ "\n" fh) ) ((= obj "LWPOLYLINE") (if (= (cdr (assoc 38 ent)) nil) (setq elv 0.0) (setq elv (cdr (assoc 38 ent))) ) (foreach rec ent (if (= (car rec) 10) (progn (setq pnt (cdr rec)) (setq pnt (trans pnt 0 1));;**CAB (princ (strcat (rtos (car pnt) 2 "," (rtos (cadr pnt) 2 "," (rtos elv 2 ) fh) (princ "\n" fh) ) ) ) ) (t nil) ) (setq itm (1+ itm)) ) (close fh) ) ) ) ) (princ) ) (princ "\nPoint Export loaded, type PTEXPORT to run.") (princ) Now I want to add Object data such as: 1. For polylines on 'LVCable' layer - CSAMetric, Conductor, FeederNo, NoOfCores 2. For polylines on other layers - CSABlue, CSANeutral, CSARed, CSAYellow, FeederNo Thank you Best wishes, Jes G Sample.dwgFetching info... Quote
asos2000 Posted February 20, 2018 Posted February 20, 2018 Give this a try http://lee-mac.com/polyinfo.html Quote
ronjonp Posted February 20, 2018 Posted February 20, 2018 If you really want to write this program, most of the legwork is already HERE. Quote
