Casusa Posted February 19, 2018 Posted February 19, 2018 Hi. On autocad 2005 in open command i can't see network drive. Network drive is running ok!! What could it be? Quote
rkmcswain Posted February 19, 2018 Posted February 19, 2018 What operating system? Is this a network share mapped to a drive letter -or- are you trying to browse to a UNC path? Can you copy the path to the clipboard, and paste it into the dialog to get there? Quote
Casusa Posted February 19, 2018 Author Posted February 19, 2018 What operating system?Is this a network share mapped to a drive letter -or- are you trying to browse to a UNC path? Can you copy the path to the clipboard, and paste it into the dialog to get there? Windows 10. It was working fine for the last 3 years. It's a network share mapped to a drive letter Quote
rkmcswain Posted February 19, 2018 Posted February 19, 2018 You did not answer the last question. If you copy the path (for example: "G:\DWG") to the clipboard, then paste that into the dialog and press enter - does it go there? Quote
Casusa Posted February 19, 2018 Author Posted February 19, 2018 Windows 10.It was working fine for the last 3 years. It's a network share mapped to a drive letter Sorry. Copy to autocad dialog box? Quote
Casusa Posted February 19, 2018 Author Posted February 19, 2018 Solved. In autocad i've mapped a new network drive. Thanks. Quote
