ILoveMadoka Posted February 9, 2018 Posted February 9, 2018 (edited) As a rule, in our BOM the QTY (quantity) equals how many of a part/assembly are included/inserted in an assembly. We've recently come across a couple situations where we need to override that number for a particular item. As an example, we have Screw X and we want the quantity to equal 100. Is there a way to get a manually entered QTY to show in the BOM for only one specific item when the BOM has many lines? For all the other items I want the QTY to equal the total in the assembly. It's like I need only 1 line in my BOM to read a Custom Property for this one item. If this do-able? Is there a different methodology for accomplishing this? I really want to avoid inserting 100 instances of this one screw in my top assembly, even if it's a pattern. (If possible) I know about manually typing in the cell to override that way... Looking for a "different" option.. Solidworks 2015 (if that matters) Please Advise Thanks Edited February 9, 2018 by ILoveMadoka Quote
SuperCAD Posted April 5, 2018 Posted April 5, 2018 You can do a manual override but it will break the link to the quantity in the assembly. If you want to restore the link, right click on the cell and select that option. Quote
ILoveMadoka Posted April 5, 2018 Author Posted April 5, 2018 I once saw a post about creating a field with a "dummy quantity" that could be read in. I wish I had saved the post and the link. Something about setting another field = to the dummy quantity field and then setting an equation so if the dummy was blank use the actual quantity else use the dummy quantity. I remember I tried it but couldn't make it work... Quote
