ghimpster Posted February 8, 2018 Posted February 8, 2018 Hi, I want to attach an Xref file into a drawing (which contains a region), and use it for extrude operation. After doing this, if I am modifying the region from the original dwg. file it will also be updated in the file with extrude (as Xref). Is this possible with VBA? I am new to it and I find it very hard to write the code (if needed) and I don't know any other way to do it. Thank you in advance, Quote
ghimpster Posted February 13, 2018 Author Posted February 13, 2018 Anyone? At least will be helpful to know if this solution is at least possible Quote
