robwell Posted January 31, 2018 Posted January 31, 2018 I am having difficulty finding the solution to a problem with my dynamic block. I hope the image helps. I would like the pointer to double pivot, but the arrowhead to stay inline with the top line. I can do this if I don't rotate the direction first. If I rotate first, the the stretch dynamic does not stay in place with the pointer and it goes crazy in it's placement. Any help is appreciated. Thanks. Here is the file. pointer.dwg Quote
robwell Posted February 2, 2018 Author Posted February 2, 2018 Anyone have any input on a fix for this? Quote
iconeo Posted February 2, 2018 Posted February 2, 2018 So you want the arrowhead to remain pointing in the same direction as the main callout arrow? Quote
iconeo Posted February 2, 2018 Posted February 2, 2018 Can you provide some examples of how you want it to look in different positions? Quote
robwell Posted February 5, 2018 Author Posted February 5, 2018 Yes. Here is a snipit example of positions. Quote
Ski_Me Posted February 5, 2018 Posted February 5, 2018 You would have to constrain the arrow to the call out tag but I think the arrow would need a point to rotate around as well. Quote
iconeo Posted February 5, 2018 Posted February 5, 2018 Try this and let me know if it works. pointer.dwg Quote
robwell Posted February 6, 2018 Author Posted February 6, 2018 That works perfect iconeo. Thanks. However, I am so stupid. While looking at your block and trying to figure out how you did it, I realized (had a DUH ME moment) as to why my original block wasn't working properly. I had unintentionally included the stretch action in the scale and rotate actions and when I removed it from both, the block worked perfectly. See attached. So, in yours, while the perpendicular, parallel, equal, move and coincident restraints work together to achieve what I was looking for, a simple stretch on polar parameter does the same exact thing without the need for those other actions or restraints. Thank you tremendously for your help though. test3.dwg Quote
