jes_g Posted January 29, 2018 Posted January 29, 2018 (edited) Hi all, I found this LISP routine by Tony Hotchkiss from here. If I understood this correct, it works with LWPolyline, Polyline and Point. For some reason it does not work will all polylines on my drawing. The sample drawing is provided below and attached with this thread https://drive.google.com/file/d/1bLurrxbnH6c9Fee5L4qIc0okwdVU0b9W/view?usp=sharing (defun vert (/ filterlist vla-obj-list lwlist 2dlist ptlist vlist1 vlist2 vlist3 ) (vl-load-com) (setq filterlist (make-filter) vla-obj-list (get-objects filterlist) lwlist (nth 0 vla-obj-list) 2dlist (nth 1 vla-obj-list) ptlist (nth 2 vla-obj-list) vlist1 nil vlist2 nil vlist3 nil ) ;_ end-of setq (if lwlist (setq vlist1 (make-list lwlist 2)) ) ;_ end of if (if 2dlist (setq vlist2 (make-list 2dlist 3)) ) ;_ end of if (if ptlist (setq vlist3 (make-list ptlist 3)) ) ;_ end of if (write-text vlist1 vlist2 vlist3) (princ) ) ;_ end of vert (defun make-list (p-list n / i vlist obj coords ca j x y z xy) (setq i (- 1) vlist nil ) ;_ end of setq (repeat (length p-list) (setq obj (nth (setq i (1+ i)) p-list) coords (vlax-get-property obj "coordinates") ca (vlax-variant-value coords) j (- 1) ) ;_ end-of setq (repeat (/ (length (vlax-safearray->list ca)) n) (setq x (vlax-safearray-get-element ca (setq j (1+ j)))) (setq y (vlax-safearray-get-element ca (setq j (1+ j)))) (if (= n 2) (setq xy (list x y)) (progn (setq z (vlax-safearray-get-element ca (setq j (1+ j)))) (setq xy (list x y z)) ) ;_ end of progn ) ;_ end of if (setq vlist (append vlist (list xy))) ) ;_ end-of repeat ) ;_ end-of repeat ) ;_ end-of make-list (defun make-filter (/ filter) (setq filter '((-4 . "<OR") (0 . "LWPOLYLINE") (0 . "POLYLINE") (0 . "POINT") (-4 . "OR>") ) ) ;_ end of setq ) ;_ end of make-filter (defun get-objects (filter / ss k lwp-list 2dp-list pt-list no-ent obj pl 2d pt ) (setq no-ent 1) (while no-ent (setq ss (ssget filter) k (- 1) lwp-list nil 2dp-list nil pt-list nil obj nil pl "AcDbPolyline" 2d "AcDb2dPolyline" pt "AcDbPoint" ) ;_ end-of setq (if ss (progn (setq no-ent nil) (repeat (sslength ss) (setq ent (ssname ss (setq k (1+ k))) obj (vlax-ename->vla-object ent) ) ;_ end-of setq (cond ((= (vlax-get-property obj "ObjectName") pl) (setq lwp-list (append lwp-list (list obj))) ) ((= (vlax-get-property obj "ObjectName") 2d) (setq 2dp-list (append 2dp-list (list obj))) ) ((= (vlax-get-property obj "ObjectName") pt) (setq pt-list (append pt-list (list obj))) ) ) ;_ end-of cond ) ;_ end-of repeat ) ;_ end-of progn (prompt "\nNo polylines or points selected, try again.") ) ;_ end-of if ) ;_ end-of while (list lwp-list 2dp-list pt-list) ) ;_ end-of get-objects (defun write-text (vl1 vl2 vl3) (setq fn (getfiled "Text File" "" "txt" 1)) (setq f (close (open fn "w"))) (setq msg "Points from LW-Polylines") (do-points fn vl1 msg 2) (setq msg "Points from 2d-Polylines") (do-points fn vl2 msg 3) (setq msg "Points from Point entities") (do-points fn vl3 msg 3) (princ) ) ;_ end of write-text (defun do-points (fn vl msg n) (setq f (open fn "a")) (write-line msg f) (write-line " x, y, z" f) (write-line "" f) (foreach point vl (setq x (nth 0 point) y (nth 1 point) ) ;_ end of setq (if (= n 2) (setq str (strcat (rtos x) "," (rtos y))) (progn (setq z (nth 2 point)) (setq str (strcat (rtos x) "," (rtos y) "," (rtos z))) ) ;_ end of progn ) ;_ end of if (write-line str f) ) ;_ end of foreach (setq f (close f)) (princ) ) ;_ end of defun (defun c:pts () (vert) (princ) ) ;_ end-of defun (prompt "PLIST.LSP by Tony Hotchkiss - enter PTS to start ") I am new in AutoLISP so I would appreciate if you could suggest me how this code can be modified to export all the coordinates of polylines for my sample drawing. Or maybe my drawing can be modified using another LISP routine. In addition, I want the program to output two files. The first file would be the XY coordinates of all points of the polylines with number (kind of identification). For example, Quote Node X Y1 359.663 162.816 2 358.596 163.075 3 358.481 163.08 4 358.379 163.045 5 358.305 162.987 6 358.234 162.857 7 355.779 153.074 8 355.753 152.623 9 355.753 152.247 10 355.804 151.921 The second file would include the points and distances between them. For example, Quote Node_start Node_End Distance1 2 1.097984517 2 3 0.115108644 3 4 0.107837841 4 5 0.094021274 5 6 0.148124947 6 7 10.08633303 7 8 0.451748824 8 9 0.376 9 10 0.32996515 10 11 0.246221445 Thank you Best wishes, Jes G Sample.dwgUnavailable Edited January 29, 2018 by jes_g attached file Quote
SLW210 Posted January 29, 2018 Posted January 29, 2018 Can you post your drawing here? I can't access cloud sights from work. Quote
jes_g Posted January 29, 2018 Author Posted January 29, 2018 (edited) SLW210 said: Can you post your drawing here? I can't access cloud sights from work. Thank you for your response. The drawing has been attached. Edited January 29, 2018 by jes_g Quote
BIGAL Posted January 30, 2018 Posted January 30, 2018 Did you ask for this before or maybe at one of the other forums, theswamp, Augi, pretty sure seen this request previously. An answer was provided. Quote
ronjonp Posted January 30, 2018 Posted January 30, 2018 One issue is that drawing contains 139 lines in it and the code does not account for them. Quote
